Hi, Im trying to capture some old VHS's and have been having a bit of a problem. When I go to capture there is no preview window. I can actually capture from the device into a file and under video preview is checked. Strangely I think when I initially downloaded ffdshow it temporally displayed an output but not any more. Im using a Digitnow BR150 which according to ffdshow is using a YUY2 format and Windows 10
Results 1 to 12 of 12
same issue here, I used to have preview working but not anymore and I don't know what I did. capture still works properly but I would like to see what I'm capturing.
it stopped working in Vdub 1 then I switched to Vdub 2. It worked for a couple days then no more preview.
probably another Windows 10 issue.JVC X550R 4K/HDR/WCG - DENON X2300W 5.1.2 DTS-X/ATMOS - Klipsch Reference Series R-26F, R-25C, R-10S - SAMSUNG K8500 UHD player - GTX1070, i7 HTPC -
I'm having the same issue. Was working fine until last weekend when I installed a new RTX 2070 and updated NVIDIA drivers.
Windows 10 Pro -
Turn off Video -> No Display? Ie, switch to Video -> Overlay or Video -> Preview, etc.
Just adding a "me too" to this thread.
I love VeeDub, but suddenly (today, actually) it no longer will show the video it is capturing. It does the capture, but no preview; makes it hard to do capture properly. It was working fine under Windows 10 for months, now... Piffle. I really hate what Microsoft is doing to everything. They seem dedicated to making all computers as useless as possible. I have moved to OBS Studio, which recommendation I found on this forum. Required some setting up, but it works, even under Windows 10.
Just my 2 frames worth... -
OBS studio has just as many problems as any other program. I gave up on it because I was not able to capture any audio. I have heard that people have lots of problems with syncing audio and video when recording from VHS which is what I am doing.
Any other solutions for displaying the preview screen for VirtualDub on Windows 10? -
I don't know if this setting really applies to the capture module, but at the main VirtualDub Interface select Options -> Preferences. In the Preferences dialog select Display in the left pane. Turn off "Use DirectX for display panes". Exit and restart VirtualDub. Try a cap...
ffplay preview window
By foldbck123 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2017, 04:22 -
capture identical as hauppauge, startech preview window
By tj1080i in forum Capturing and VCRReplies: 4Last Post: 12th Oct 2016, 22:50 -
Any program that makes the top window 'current window' esp win7?
By pcGnome in forum ComputerReplies: 6Last Post: 23rd May 2015, 17:43 -
How do I set preview window size in VirtualDub?
By paulot in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2015, 16:36 -
.TS video slowing down in a preview window, but fine on the timeline
By Mayx in forum Newbie / General discussionsReplies: 5Last Post: 31st Jul 2014, 23:50
