Hi. I've used a script like this many times:
but with the vid I'm currently trying to use it on, I get the error "Splice: video framerate doesn't match"Code:trim(100,1000)++trim(200,500).SmoothFPS2(int(framerate*3), 2).AssumeFPS(framerate)
Given this is the first time I've seen this error with a tried and tested script, I can only assume the vid is 'rogue' unless someone can suggest cause and cure...
Thanks for your time.
Turned out to be a simple fix - use FFVideoSource instead of LSMASHVideoSource. There must be some kind of conflict between this particular vid and Smash as it's never before refused the SmoothFPS2 command.
Odd aspect ratio issue...
By Animator811 in forum Authoring (Blu-ray)Replies: 6Last Post: 18th Nov 2017, 18:24 -
avisynth: it's necessary VFRtoCFR using already SmoothFPS2?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 1st Nov 2017, 09:24 -
odd VCR issue with comets question
By mazinz in forum Capturing and VCRReplies: 2Last Post: 17th Jun 2015, 16:50 -
Odd 'localhost' php issue
By DB83 in forum ComputerReplies: 14Last Post: 19th Jun 2014, 15:57 -
LOST on DVDs (PAL - R2): odd issue
By Instant Martian in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2013, 12:06
