I am trying to losslessly (if possible) fix the aspect ratio of an MPEG-2 video in a VOB file.
(You can get the first few seconds here: input.vob)
Its actual pixel dimensions are 720x480, but SAR 32:27 DAR 16:9 (according to ffmpeg -i), and I want it to be DAR 4:3. I figure it should be just a matter of changing some metadata to get the DAR to be 4:3. But I tried every combination of ffmpeg options I could think of, to no avail. These did not help:
In each case, the output.vob still has SAR 32:27 DAR 16:9, even though FFmpeg claimed it was going to write SAR 8:9 DAR 4:3. The same thing happens if the output is specified as output.m2v; it's not specific to the VOB container.Code:ffmpeg -i input.vob -aspect 4/3 -c copy output.vob ffmpeg -i input.vob -bsf:v mpeg2_metadata=display_aspect_ratio=4/3 -c copy output.vob ffmpeg -i input.vob -bsf:v mpeg2_metadata=display_aspect_ratio=4/3 -aspect 4/3 -c copy output.vob
Various attempts at transcoding also fail in the same way:
Weirdly, the setsar filter seems to be more effective than any other at getting ffmpeg -i to show the right SAR/DAR for output.vob, but it still plays as 16:9 in VLC:Code:ffmpeg -i input.vob -vf setdar=dar=4/3 -b:v 6000k -maxrate 7000k -bufsize 1835k -c:v mpeg2video -c:a copy output.vob ffmpeg -i input.vob -aspect 4/3 -vf setdar=dar=4/3 -b:v 6000k -maxrate 7000k -bufsize 1835k -c:v mpeg2video -c:a copy output.vob ffmpeg -i input.vob -bsf:v mpeg2_metadata=display_aspect_ratio=4/3 -vf setdar=dar=4/3 -b:v 6000k -maxrate 7000k -bufsize 1835k -c:v mpeg2video -c:a copy output.vob ffmpeg -i input.vob -aspect 4/3 -bsf:v mpeg2_metadata=display_aspect_ratio=4/3 -vf setdar=dar=4/3 -b:v 6000k -maxrate 7000k -bufsize 1835k -c:v mpeg2video -c:a copy output.vob
However, if I transcode to H.264, then there is no problem, I get 4:3 output as expected:Code:ffmpeg -i input.vob -vf setsar=sar=8/9 -aspect 4/3 -c:v mpeg2video -b:v 6000k -maxrate 7000k -bufsize 1835k -c:a copy output.vob
Is there no way to fix this video's DAR when writing MPEG-2 output? (losslessly, I hope)Code:ffmpeg -i input.vob -aspect 4/3 -c:a copy output.mp4
If you have a VOB, then you have the DVD as well? If so, open the DVD in PGCEdit. Right-click on the video in question and hit 'Domain Stream Attributes'. In there change from 16:9 to 4:3. Save your work and test.
If you have only the VOB, you can demux, fix the M2V in ReStream, followed by remuxing. -
VOBs are more than just MPEG ProgramStreams, they contain also DVD Video specific metadata. And IFO files as companion to these VOB segments contain some as well.
If you want to patch attributes in a DVD Video medium, try to use the DVDPatcher. – And manono knows good advices too. -
It is a VHS transfer that someone decided to put into a VOB, so no DVD source available.
Thanks for suggesting ReStream. At first I thought it would not work because it was reading the demuxed m2v as 4:3 and thus makes no changes to it. But then I looked at the other info it provided, and saw "Sequence Display Extension" with horizontal size 540. Not sure what it means, but changing the drop-down in that section from "don't change" to "remove" solved the problem and made the DAR be 4:3 per ffmpeg and playing with the correct ratio in VLC. -
FFMpeg setsar and setdar video filter does not exactly set the sar and dar
By alexander121 in forum Video ConversionReplies: 2Last Post: 15th Oct 2017, 09:57 -
Capturing TV broadcast 4:3 and 16:9 DAR
By wiseant in forum Capturing and VCRReplies: 8Last Post: 22nd Jan 2017, 15:20 -
change DAR 16:9 TO 2:35:1
By anime12345 in forum Video ConversionReplies: 7Last Post: 31st Aug 2015, 17:04 -
DAR confusion
By adom in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2014, 00:50 -
Helping friend with camera files
By Bigten333 in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2014, 23:37
