Via command-line:
ffmpeg, x264cli (or a pipe ffmpeg->x264cli/x265cli)
GUI:
MeGUI
But StaxRip should support it, I think. If you don't have any luck using its AviSynth pipeline try the VapourSynth one.
Note:
10 bit+4:4:4 doesn't imply HDR. If you do actually encode with HDR note that x264 doesn't support the HDR metadata described in the H.264/AVC spec. Better to use x265, then. (It's possible to add metadata e.g. on the mkv container level, though.) -
sneaker is absolutely right.
ffmpeg has added support to encode 8-bit and 10-bit for x264 and x265 within the same executable since February of this year (see https://ffmpeg.zeranoe.com/forum/viewtopic.php?f=2&t=5475).
Before you have had to create your own 10-bit builds and to work with separate executables for 8-bit and for 10-bit.
So, you can use ffmpeg now to create an encode based on a PRORES video with pixel format yuv422p10le (or even yuv444p10le). And you can use it to create x265 HDR10 encodes if your source is HDR.
I've read certain times that the guys creating encodes of their UHD HDR Blu Rays are using StaxRip. So it should have those capabilities, too. -
VapourSynth does what I want, thanks for the enlightenment guys.
VHS to computer h.264 vs h.265?
By Computerman1 in forum Capturing and VCRReplies: 6Last Post: 12th Sep 2017, 17:42 -
Shall i take H.264 OR H.265 ?
By Anonymous754 in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2017, 10:27 -
H.264 or H.265?
By SameSelf in forum Video ConversionReplies: 29Last Post: 30th Jun 2016, 13:03 -
Physical Media Player that supports H.265, 10bit and lossless Dolby/DTS?
By VideoFanatic in forum Blu-ray RippingReplies: 0Last Post: 30th Oct 2015, 13:34 -
Lossless burning MKV H.264 10bit video to DVD????
By uranometria in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2014, 07:11
