Hi, have this model of firewire card. PE-101
It comes with extra 4 pin (fdd) energy suply and it is culprit of my problem. I need this molex for different things. So is it safe to remove this extra power suply from firewire card when I'm 100% sure, that only usage of this Firewire is capture from camera? Camera has of course its own power suply.
I think it is safe, but need to be sure for 100%.
Edit: it is in PCIe 3.0x1 slot. but it is mentioned in link i suppose
Thank you in advance.
Bernix
Results 1 to 10 of 10
If your camera has separate power then it is fine - 4 pin FW interface is unable to provide power to external device.
AnonymousGuest
maybe there are splitter cables available?
AFAIK this 4 pin connector gives extra power to the extension board to eliminate too much power drain from pcie bus.
But l agree with pandy that if your camera has it's own power supply it will be alright -
Ok. Thank you Pandy and Jan5678
As usual I was unclear. I have FW with two 6pin outputs. And FW has suply from PCIe and from floppy disk suply (4pin) <- and I want remove this.
It can be confusing, that i talked about 4pin fdd at 6pin output FW. But I got it. It is safe to remove it.
But I'm sure you get it right, when question was probably shroud in fog.
Thank you very much!!!
So I will remove it without any consequence. But find out it is working lately, all cassettes are already captured.
See you and have a nice day!
BernixLast edited by Bernix; 12th Jul 2018 at 09:54. Reason: credit to Jan5678 as well
Well, not sure why you wish to remove Molex fdd power like connector from your card but for sure 4 pin FW doesn't provide anything above data - to provide power to external FW devices a 6 pin FW interface must be used.
Glad to read that everything work OK for You, thx and have a nice day too. -
In short, and to close this thread. I buy bit expensive PSU from corsair 80+ gold that has two conectors to power supply GPU. But provide just one cable 6+2 pin. (can coast 5 cents) the price for PSU was about 100+ dollars. And now I need reduction molex - 8pin or 6pin it takes two molex conectors and I have only 4 in total. Also I need more fans another molex reduction. So have to find someone somewhere. And this feeding firewire seems to me be best. It should go smoothly without it. That is end of story.
Thanks for help all.
Can be closed.
Solved. -
This Molex may be current limited (do not forget about limited capabilities for PCB traces), i would go for splitter and i would avoid to use for anything serious (power) this PCB Molex. Power splitter on auction portal (Aukro or similar) that you can pickup personally should be not so expensive. For multiple fans i would go also for fan controller.
Hi,
already solved. But don't understand PCB traces. It is ordinary molex, ocupied with reduction to flopy disk drive. It is used to feed FW with additional electicity. So I think it is ordinary molex as any other molex.
It is like here https://i.ebayimg.com/images/i/350852253454-0-1/s-l1000.jpg
According to virustotal it is clear, but do not inserted it as active link. It made itselfs.
Thank you again.
BernixLast edited by Bernix; 12th Jul 2018 at 13:13.
Ok, my point was that this Molex connector mounted on FireWire card is powered trough motherboard traces and PCI socket then card PCB traces itself - as such if you start sinking too much current there is risk that something may be corrupted. So if your intention is to powering not demanding sink then everything is fine. Not sure also if there 12 or 5V on this connector - nominally it can be 12V but 5V not necessarily. Hope now it is clear.
Remuxing with MKVtoolnix removes thumbnails
By RubbleToes in forum EditingReplies: 2Last Post: 10th Jun 2018, 11:54 -
Premiere Pro CC removes most of my audio
By EpicReach in forum EditingReplies: 2Last Post: 27th Nov 2016, 19:37 -
Firefox 45.1 update removes Sound?
By ahhaa in forum ComputerReplies: 11Last Post: 15th Apr 2016, 08:28 -
s/w that removes pauses between spoken words
By BobAchgill in forum AudioReplies: 1Last Post: 7th Aug 2015, 23:12 -
VobSub Removes MPC's Subtitles
By lomaidala in forum Software PlayingReplies: 4Last Post: 14th Dec 2013, 19:48
