I want to do a loss less 4k trim of a mp4 file but it only gives me a mkv file. I want the output to be a mp4 file. my editing program doesn't accept mkv. steve
Results 1 to 14 of 14
[but it only gives me a mkv... it? Doesn't explain what IT is. Neither does... my editing program...? Are you open to other programs or do you need help with IT? There are several others that should work. It sounds as if you wish to cut and join using copy and then edit with another program. Correct?
You could use Xmedia Recode to quickly convert MKV to MP4. Set the output to MP4 and set video and audio streams to copy.
thanks for the advice. I will try xmedia recode.I use that all the time. My files are 4K, 100mbps, 25 to 80 gig files. I tried to open a 27 gig video with avidemux, and it froze the computer,
so I had to power it down and turn it on again. So maybe there's a limit on how large a file you can work on. -
The limit is your hardware; you need massive amounts of ram to work with files that large; AviDemux is trying to load that file into ram and since there's nothing left for any other running program, your system will freeze.
AviDemux is the wrong app to use to work with files that large unless you have lots of ram, and I mean LOTS. -
Use dmMediaConverter Split mode and put .mp4 at the output file name. Very easy!
dmMediaConverter creator -
I'm thinking of buying 8 gig more. that would give me 12. I have another computer that has 16. is that enough?
I'd like to try the dmMediaConverter - v2.1.0 but i haven't been able to download it.
MP4Tools(MP4Splitter) did the job for me.
https://www.mp4joiner.org/en/
All I wanted, it was to cut approximately 10GB MP4 file into 3/4 parts without re-encode, and software did it fine.
Definitely it can be done with ffmpeg and command line, but with GUI, it was easier for me.
Maybe there will be problems with your files, because as you said, you have BIG ones. But give it a try, software is free, and simple to use.Last edited by TempUser_; 18th Jul 2018 at 12:15.
How come? The links are valid.
Here it is the direct links. For win choose the zip file v2.2
https://drive.google.com/drive/u/0/folders/0B1MiTYJef5a9TG9kMC04WWE3YkUdmMediaConverter creator -
I'm trying to merge 3 4k camcorder files and it's failing. this is what I'm getting
ffmpeg version 3.4 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 7.2.0 (GCC)
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 03ad8960] Auto-inserting h264_mp4toannexb bitstream filter
[concat @ 03caae20] Could not find codec parameters for stream 2 (Unknown: none): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, concat, from 'C:\Users\User\AppData\Local\Temp\dmMediaConverter _20181006_185620978\mergeTempFile_20181006190123.t xt':
Duration: N/A, start: 0.000000, bitrate: 100056 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709/bt709/iec61966-2-4), 3840x2160 [SAR 1:1 DAR 16:9], 98520 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc
Metadata:
creation_time : 2018-10-06T19:46:45.000000Z
handler_name : Video Media Handler
encoder : AVC Coding
Stream #0:1(und): Audio: pcm_s16be (twos / 0x736F7774), 48000 Hz, stereo, s16, 1536 kb/s
Metadata:
handler_name : Sound Media Handler
Stream #0:2: Unknown: none
Cannot map stream #0:2 - unsupported type.
If you want unsupported types ignored instead of failing, please use the -ignore_unknown option
If you want them copied, please use -copy_unknown -
Looking for program to split/trim vob files and export as lossless
By 90sTV in forum Newbie / General discussionsReplies: 13Last Post: 7th Jun 2018, 19:57 -
X265 "Lossless" not really lossless and I can prove it
By sophisticles in forum Video ConversionReplies: 21Last Post: 3rd Feb 2017, 22:54 -
how to trim in FFMPEG?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2015, 11:04 -
Premiere export to lossless is not lossless
By Dogway in forum EditingReplies: 66Last Post: 30th Dec 2014, 14:48 -
trim video
By abhaybad in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2013, 14:24
