Hello all!
I am in the process of editing a project that contains videos with multiple frame rate. Half of the videos were filmed on my home camcorder at 29 FPS, and the other videos are from a Blu-Ray I ripped to my computer (Rocky) which is of course 24 FPS.
Is there any way for me to render the final product in a way in which all of my camcorder footage appears at its original 29 FPS and the Rocky clips appear at its original 24 FPS? Or is this not possible? (Right now, I'm rendering the full project at 29 FPS, so my camcorder footage appears great, but the Rocky footage looks terrible).
For reference, I edit in Sony Vegas Pro 12.
Thanks for any advice!
Tony
Is that camcorder footage 29.97i, interlaced?
Then batch convert all those 29.97i clips into 59.94p (you can use yadif bob or qtgms to be perfect), use some avi losless container, like huffyuv or utvideo. You can use VirtualDub2. Give them the same names as original clips and then in Vegas replace those 29.97i clips with those 59.94p clips in that finished project.
Then for those 23.94p clips use disable resample in Vegas , and Vegas just should duplicate frames if rendering to 59.94p, it should not look that bad.
Of course set your project to 59.94p and export to that frame rate as well. -
Hi Al!
Wow, your suggestion to disable resample in Vegas was amazing!!!! That was exactly what I needed. I did that, and now the Rocky movie clips look perfect. I'm shocked that worked so easily. My camcorder footage actually looks great as well even without converting. However I will also give that a try just to see how it looks, though I think this may have even been all I needed.
What exactly is resampling? Is "smart resampling" adding frames, but "disabling" resampling simply keeps the frame rate "as-is?"
Thanks again for your help, really appreciate it! -
From the fine manual:
Smart resample
Resampling entails interpolation of new frames. In the absence of resampling, Vegas duplicates frames to achieve the project rate.Resampling occurs only when an event's calculated frame rate does not match the project frame rate and the project frame rate is 24 fps or greater. The calculated frame rate takes into account any changes made to event speed with velocity envelope, playback rate, and undersample rate.
Force resampleThe event is always resampled, regardless of its frame rate or the output frame rate.
Disable resampleNo resampling will occur.
How do I avoid choppy video going from 60fps to lower frame rates?
By doncaruana in forum Video ConversionReplies: 13Last Post: 24th Nov 2017, 08:01 -
How to keep original VBR rates on rendering
By Bencuri in forum Video ConversionReplies: 15Last Post: 25th May 2017, 19:28 -
Tool for Multiple Frame Rates to 24 fps
By ensignrickyto in forum Video ConversionReplies: 3Last Post: 16th Sep 2015, 11:02 -
Rendering Video in Sony Vegas While Preserving Multiple Audio Tracks?
By Evil Joe in forum EditingReplies: 7Last Post: 26th Jul 2014, 19:37 -
Highest video frame rates (consumer grade)
By dbooksta in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 19th Feb 2014, 01:09
