I have a second-hand Sony SLV-777. Since last week, everything has started to went wrong about this VCR. Having poor digital tracking and low sound makes me think it's completely dead. And also, it makes weird sounds while playing a tape. What should I do? Should I clean the heads?
Results 1 to 9 of 9
Rest in peace VCR XXXX-2018 lived by the drum,n died by the drum
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
There is a problem with the tape transport. Open it up and watch it while it plays. Is the tape reasonably taut or is there slack? Where does the noise come from?
If you care about it, it need to be serviced. Tracking issues can be anything, problems with the trape transport, guide misalignment with the drum... Other issues with old devices like this are dry out electrolytic capacitors that has a life span of about 15 years, so. There is nothing you can do by yourself and cleaning the drum heads wont do anything to make it better.
Update: It doesn't happen everytime. It only happened when I inserted a old and extremely damaged tape. I think the damage is incorrectable. Screen goes black when I play the damaged portion of the tape. Also, sound is very low at some portions of the tape and at some portions, there's no sound. Maybe some professional tools like hi-end TBCs can correct that.
Last edited by AmanoAi; 18th Jul 2018 at 10:37. Reason: I don't need a Panasonic AG-1980
That looks to be a low-end consumer deck, not worth fixing.
In fact, not worth using at all for video transfers, if you care about the quality.Want my help? Ask here! (not via PM!)
No, it wasn't a low-end deck. it was a prosumer deck. I didn't track the tape manually and turned off auto tracking during the playback to see the damage
. If the picture and sound don't get better when I manually track the tape, there can be a serious problem. And that's what I'm afraid of.
No, that's a vanilla VHS deck and Sony consumer machines don't wear very well.
Stop playback during a damaged portion, eject the cassette, open the door, and have a look at the tape. If it's crinkled, that's your problem. Playing a damaged tape is hard on the video heads.
I want to learn VCR repair PANASONIC VCR maintenance information Books With
By 280634157 in forum Capturing and VCRReplies: 9Last Post: 18th May 2018, 17:20 -
The PC is Dead
By SameSelf in forum Off topicReplies: 313Last Post: 26th Jul 2016, 12:52 -
VHS tape got stuck in VCR, now VCR plays full static
By Rand251 in forum Newbie / General discussionsReplies: 21Last Post: 4th Apr 2016, 10:40 -
Capturing VHS with VCR or Blu-ray/VCR combo?
By SyncroScales in forum Capturing and VCRReplies: 11Last Post: 26th Dec 2014, 09:39 -
Symphonic 6300 VCR working fine, display dead
By vintagevcr in forum Newbie / General discussionsReplies: 10Last Post: 23rd Jun 2014, 06:29
