Closed Thread
Results 1 to 11 of 11
  1. This post has a copyright trouble
  2. Need to find m3u8 link
  3. Да только не качается по .m3u8.
  4. Hi! Encrypted stream: EXT-X-KEY:METHOD=KOOLEARN-ET. Therefore, it is not downloaded.
  5. Livestreamer:
    Failed to create decryptor: ('Unable to decrypt cipher {0}', u'KOOLEARN-ET')
  6. I screen captured most of the video with Debut free (fair to poor quality).
    Link to Debut free:
    https://files.videohelp.com/u/61125/debutsetupfree.zip
    Link to captured video:
    https://files.videohelp.com/u/61125/z.avi
  7. sysanin. Не переживайте, streamlink пишет тоже самое. Поток зашифрован: EXT-X-KEY:METHOD=KOOLEARN-ET.
    Не взять его. Вы писали про проблемы со Streamlink. Это какой-то конфликт с ОС. Я беру с оффициальной страницы.
  8. Member Emeritus
    May 2014
    Смотреть следующий пост ...
  9. Encrypted stream: EXT-X-KEY:METHOD=KOOLEARN-ET. Therefore, it is not downloaded.
    https://pl.koolearn.com/api/hls/m3u8_free?sign=_mtCSSUSdD_9yRTiJsAmh4K3HJE&timestamp=1531250199132&consumerType=1002001&encrypt=0&videoId=140952&userId=-1&videoType=1
    [Attachment 46038 - Click to enlarge]
  10. Да, на Android отдаёт AES-128. Не было времени рыться. Но понял ли господин Zacker, что и как ему делать?
  11. OK, I was able to download the video with above screenshot from sysanin and youtube-dl.
    Link to downloaded video:
    Code I used (but you will have to get your own https code because they expire):
    youtube-dl "https://pl.koolearn.com/api/hls/m3u8_free?sign=Mje3bN0QymQXrAWBckM3zMCt2Gk&timestamp=1531273886065&consumerType=1002001&encrypt=0&videoId=140952&userId=-1&videoType=1"
    See below screenshot. I use Firefox with user agent set to Android. If I didn't set the user agent to Android, I couldn't get the necessary code. The red circles indicate the important settings. The data string in lower right of screenshot is what I copied and used with youtube-dl. Interesting that I was not able to download this video with the usual software that I paid for.
