What's the best software to split / remove middle parts of an MKV without re-encoding it. I've been using Boilsoft, but they still haven't fixed the MKV issues I've noticed.
For example:
- I have a 2 minute and 30 second video
- Start set to 1 minute and 25 seconds
- End set to 2 minutes and 15 seconds
- Video finishes and it alters the start and end points
- Resulting start set to 1 minute and 32 seconds
- Resulting end set to 2 minutes and 25 seconds
- Even adjusting it a few seconds up and down myself results in it forcing the resulting start and end points to the same times it forced previously.
So now I have clips that have 5-15 seconds at the beginning and end that I can't get rid of no matter what I do.
You can cut mkv's only at key frames. Your rip is bad
Use ordered chapters for that, no cutting, no joining. Play content you want only.
MKV Splitting
By Ippothechamp in forum Newbie / General discussionsReplies: 8Last Post: 1st Apr 2018, 17:49 -
MKV Toolnix: Splitting and Joining?
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 2nd Jun 2017, 15:19 -
Splitting h264 (no re-enc.), difference mkv and mp4?
By Spiny Norman in forum Video ConversionReplies: 5Last Post: 23rd Dec 2015, 14:48 -
Having trouble splitting MKV
By NotSoEasy in forum EditingReplies: 7Last Post: 24th Apr 2014, 13:59 -
Splitting Very Large Raw h.264 or MKV files
By aghead in forum Newbie / General discussionsReplies: 4Last Post: 15th Apr 2014, 20:34
