Hi Guys,
This question may have been asked a milion times before but unfortunately i couldn't find a good solution to my issue.
I want at first to get my raw data out from the DVD, exactly the same quality without any compression.
For that i'm using "Normal Recompress".
At this point already i see big differences in quality- the VOB file has better picture, real smooth transition between frames..
Probably i'm doing it the wrong way, so how can i get the same quality in an AVI file?
You won't get the same quality out of an "AVI" file.
These days you probably don't NEED an "AVI" file.
An MKV file gives you identical quality(no recompression at all) as the original DVD....just in a more playable container.
If smaller file size is not your main objective.....look into MKV. -
Tried making a lossless MKV, don't understand how the file size got up to X20 of it's original size?
Smaller file size is not my main objective but i would expect the same file size.. am i wrong?
In addidtion, after converting to MKV i still see big quality differences between the original and the new one...
Thank you for your help -
Your DVD contains MPEG 2 compressed video. When you save that to an MKV file with a lossless codec you are first decompressing the MPEG 2 video (growing maybe 50 fold in size) then compressing those uncompressed frames with the lossless codec. Lossless codecs usually on give a factor of 2 to 3 compression. So the losslessly compressed video will still be much larger than the DVD source.
hech54 is inaccurate when he says AVI can't achieve the same quality as MKV. Both can contain lossless codecs. AVI can even contain MPEG 2 video, like MKV. But there are few programs/players that can deal with MPEG 2 video in an AVI container. So if your goal is to copy (not further compress) the video and audio from the DVD to a file that can be played across a wide variety of platforms use MKV...
As was pointed out, use MakeMKV. It simple re-multiplexes the original MPEG 2 video and AC3 audio from the DVD to an MKV container.
TS to DV AVI 1 Conversion?
By Art44 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Jan 2016, 20:43 -
mp4-avi conversion help
By Deblk in forum Video ConversionReplies: 9Last Post: 13th Jun 2015, 13:57 -
mp4 to avi conversion help
By grizzly_ in forum Video ConversionReplies: 32Last Post: 27th Jan 2015, 22:29 -
Out of sync audio for AVI to DVD conversion
By Mandera in forum Authoring (DVD)Replies: 5Last Post: 30th Jul 2014, 00:12 -
VOB to AVI conversion
By rank17 in forum Video ConversionReplies: 4Last Post: 4th Jul 2014, 15:07
