Hi All,
I imported with the 1920*1080 video into Virtual Dub. I wanted to remove the black bars from the videos.
Here is what i did:
1.Video>Filter>Add>Null Transform>Remove the black bars
2. Save as AVI
When i save the video , the videos still showing as the original video , it did not remove the black bar as i edited in filter.
Any suggestion to fix it? I also attach the image as well.
[Attachment 46014 - Click to enlarge]
Did you select a compressor before saving to avi (click Video > Compression)?
Did you change to Fast Recompress or Direct Stream Copy after setting up the crop filter?
I think his image is simply showing the input and output (with cropping) panes in VirtualDub -- of his original video, not the saved video.
Hi Sirs, sorry for mislooking the thread. I wanted to remove the left and right side black bar. I try with direct stream copy and save as avi, but the video is not cropped one. It is still showing two side black bar. I wanted to save the video after i cropped it in the filter. The filter only work if i chooe the full processing mode but it make alot space for one video like 40gb.... so i try run with direct stream copy and then save as avi, but still can't remove the two side black bar..
Direct Stream Copy mode does not allow any filtering. The video isn't changed in any way. The compressed video stream is simply copied from the input file to the output file.
Full Processing mode is the only mode that allows filtering. Cropping (or any other filtering) requires that the compressed video be decompressed before filtering. If you want compressed video again you must select and configure a compression codec with Video -> Compression...
Sony Vegas - Cropped Video Still Showing on Edges of Frame
By smilotron in forum EditingReplies: 1Last Post: 2nd Jun 2017, 20:27 -
Windows 7 video player that can save URL videos with applied video effects?
By coolvibe in forum Newbie / General discussionsReplies: 7Last Post: 13th Jun 2016, 17:52 -
saving a cropped section of video ?
By spearfishman in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2014, 17:49 -
Video that views fine in VLC - appears cropped in Premiere Pro/other suites
By supersi in forum Video ConversionReplies: 1Last Post: 10th Oct 2014, 00:15 -
Video will not save properly
By pacificus in forum EditingReplies: 2Last Post: 26th Nov 2013, 19:48
