I got my old 3/4" Umatic Sony deck out. After running the transport briefly, I was getting error 2 on the machine panel. Apparently this code is tape slack. Anyone know of a fix for this or does it mean I'll have to find someone who can still repair these decks and take it in?
Open it up and, with the lights down low (or cover up the tape sensors), take a look at what is happening. Is the takeup reel turning in PLAY mode?
It came up with this error in rewind mode as well as play. My one video guy seems to think it could be a belt issue, but I don't know if this deck uses belts or is direct drive. It wouldn't even go into play mode, so I suspect your answer may be no.
The reels probably aren't being driven. There is a belt that powers the idler and it could be worn out. Or the idler tire is hardened and doesn't grip the reel tables. Or the idler doesn't swing back and forth properly. Fixing any of these problems means taking the deck apart to some extent and may require replacement parts.
Ok. Kinda what I figured. Problem is finding someone in Vancouver that will still fix these old decks, assuming it can still be fixed.
You may have to ship the unit some distance. I'm in the same boat, which is why I have learned to do some repairs myself.
Frame drift on broadcast tape?
By 90sTV in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2016, 17:04 -
BMD Intensity Pro 4K "includes a professional, broadcast grade TBC" (Nope!)
By Brad in forum Capturing and VCRReplies: 22Last Post: 24th Jun 2015, 19:02 -
Advice sought re: 1. "Dead" VHS tape. 2. "Blackouts" throughout transfer.
By tj7 in forum RestorationReplies: 46Last Post: 2nd Jun 2014, 20:59 -
Noise in Sony Hi8 EVO-9850 Playback
By Jim Norman in forum RestorationReplies: 12Last Post: 27th Oct 2013, 21:04 -
DV Deck Error
By miniDVhelp in forum Video ConversionReplies: 7Last Post: 21st Aug 2013, 11:29
