I have this script for enhancing the audio on movies or clips. so when I dropped a .mp4 clip on the script all i get is this below in the cmd window. anyone know why
Code:Audio processing, video is copied losslesly C:\ffmpeg-3.4-win64-static\bin\ShapeMaker: No such file or directory Press any key to continue . . .
this is the script I use
@setlocal
@echo Audio processing, video is copied losslesly
@rem folder where ffmpeg.exe is located
@set FF=C:\ffmpeg-3.4-win64-static\bin
@set PATH=%FF%;%PATH%
@set filename=%1
@rem audio bitrate
@set ab=192
@set aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,dynaudnorm=p=1/sqrt(2):m=100=20"
@ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -c:v copy -af %aproc% -c:a aac -b:a %ab%k -f matroska "%~n1_dynaudio.mkv"
@endlocal
@pause
Be careful in batch files with percent signs. Sometimes need 2 (%%) and sometimes not depending if its batch usage or program usage as part of ffmpeg line. %%A usage is also different than %1.
Also removing the @ signs and allowing lines to show complete output may help with errors. -
Change this line in your script
toCode:@set filename=%1
and see if that helps.Code:@set filename=%~1
I am a bit confused with this above I did remove all @ signs. but got a load of junk stuff
pandy
Re: ffmpeg help not working
Check if your C:\ffmpeg-3.4-win64-static\bin exist and if there is ffmpeg.exe in this folder.
yes ffmpeg.exe is in that bin folder
JVRaines
@set filename=%1
to
@set filename=%~1
I cant see how to make that symbol @set filename=%~1 after the % sign I think its called tidle not sure now
EDIT: Silly me its LSHIFT and the # key like this ~ I just added that ~ symbol like you said between the % and the 1 so its like this @set filename=%~1
now it works seem weird to me as it worked before that ~ was there, but its working now
thanks so muchLast edited by loa909; 9th Jul 2018 at 09:49.
You're welcome. Here's why it works: If you drag-and-drop a file on this script and there are any spaces in the pathname, then Windows will surround the value with quote marks. Since you are also putting quotes around %filename% in the call to ffmpeg, you will end up with doubled quotes on each side, like this
""C:\Users\Bozo\Desktop\My Lovely Video.mp4""
The doubled quotes are treated as empty strings, so the pathname is unquoted and ffmpeg breaks it up on the spaces. Thus, it sees only "C:\Users\Bozo\Desktop\My" as the input file.
Using the tilda in %~1 tells the command processor to remove any surrounding quotes from the parameter. Then, it becomes properly quoted in your call to ffmpeg. -
well many thanks to all of your replies but now I have added that symbol ~ its working fine.
ffmpeg drawtext not working
By vhelp in forum ProgrammingReplies: 21Last Post: 5th Feb 2017, 21:34 -
Ffmpeg with http proxy not working
By Karol in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Nov 2016, 09:22 -
FFMpeg : List of working sample formats per format and encoder.
By alexander121 in forum AudioReplies: 0Last Post: 31st Jul 2015, 12:17 -
MKV to MP4 video not working after FFMPEG copy
By contraplex in forum Video ConversionReplies: 3Last Post: 26th Jul 2015, 06:40 -
ffmpeg.exe has stoped working
By downer in forum SVCD2DVD & VOB2MPGReplies: 33Last Post: 6th Aug 2014, 16:45
=20"
