Results 1 to 11 of 11
    Jul 2018
    Firedept
    How to achieve the quality of X264 "2pass slow" with NVENC HEVC? I used the Nvidia Card's picture quality enhancer (sharpening), and the results were fantastic.
    I used the latest version of Staxrip, updated only some files manually.
    Here is the sample file, I cut it out from blu-ray without re-encoding: 1080p@23.97 (600 Mbyte)
    You can download it here (until a week) https://wsi.li/BEAWwFwfV7wQ
    and you can repeat the test too.
    REMEMBER: the file sharing service will delete automatically the files after 7days.
    X264 2pass Slow option with the basic settings ("factory settings") proved to be similar or a bit worse than NVENC HEVC at the same bitrate with its built-in HARDWARE supported picture enhancer/sharpener.
    I encoded both material with 2000 Kbit/sec, and later with 3800 kbit/s (average Youtube bitrate)
    You can download the results here:
    X264 2pass SLOW 2000 Kbps (48 Mbyte)
    https://wsi.li/6iOFE54gW2Re
    __________________________
    NVENC HEVC 2000 Kbps (49 Mbyte)
    https://wsi.li/o3uZ5UjpchUU
    _____________________________
    The most important tests:
    X264 2pass SLOW 3800 Kbps (88 Mbyte)
    https://wsi.li/TfvHGS4LJRd0
    NVENC HEVC 3800 Kbps (88 Mbyte)
    https://wsi.li/Tq3QBRHhMqc6
    X264 staxrip settings
    NVENC HEVC STAXRIP settings:
    THE MOST IMPORTANT SETTING of the enhancer:
    __________________________________________________ _________________________________
    Results in pictures: Save the images to watch them in full resolution, or copy the "image url" and open them in new tabs.
    X264 (3800 kbps)
    NVENC HEVC 3800
    I worked two days for the perfect option of the best settings for the enhancer.
    Aug 2013
    Central Germany
    Is this undeclared advertizing?
    Jul 2018
    Firedept
    If you send me money, than it will be an advertisement.
    Jul 2018
    Firedept
    X265 2pass SLOW (factory settings) WAS humiliated by NVENC h265 with this settings:
    https://image.ibb.co/fCsqcT/image.png
    X265 2pass SLOW video (88Mbyte)
    https://wsi.li/quEHu71ZWXCd
    NVENC HEVC (88 Mbyte)
    https://wsi.li/qGAp5097rJ5J
    It is shocking good!!!!!!
    I used only my GPU for image enhancement process and compress, and I achieved the quality of the X265 2pass SLOW.
    So a video card with clever settings can create very very very good quality.
    Images:
    X265 2pass SLOW:
    NVENC HEVC pictures
  5. Thanks for share the settings. That help me to rip a lot of videos and save time!
    If you have new settings, please share it
    Dec 2012
    Germany
    here are the Staxrip Settings for NVENC h264 on x264 placebo quality Level which encodes with 800+ fps on a 4:3 PAL DVD file. where placebo reaches only 14 fps per second on a 2700X
    encoding is done with the Turing encoder on a 1660 Super
Name:	01 basic.jpg
Name:	02 rate control.jpg
Name:	03 slice decision.jpg
Name:	04 analysis.jpg
Name:	06 other.jpg
    Aug 2013
    Central Germany
    Is this now "the Flat Earth of video compression"? How do you prove your "same quality" claim?
    Dec 2012
    Germany
    You need proof for your eyes not seeing compression artifacts? Do you need proof that the sky is blue or that trees exist?
    Aug 2013
    Central Germany
    I want to see it with my eyes, not rely on yours.
    PS: Not seeing any artifacts is no proof and no miracle. I want to compare some visible artifacts at the same bitrates for how annoying they appear to me.
  10. Not to rain on anyone's parade, but of course nvenc matches x264+placebo in this test, I would have been shocked if it didn't.
    Look at the test settings, source is "4:3 PAL DVD" and according to the screenshots he used a max of 17.5 Mb/s, max bit rate for DVD is 9.8 Mb/s mpeg-2, both those encodes are probably close to mathematically lossless at the tested bit rate.
    Aug 2013
    Central Germany
    The real challenge is not to show no noticeable artifacts (due to plenty bitrate), but to make the inevitable noticeable artifacts (due to limited bitrate) look less annoying.
