I read the rules and I am using my encodes for my own personal videos, but there is a particular release group can create conversions that exceed what I am capable of reproducing and I need to know how to reproduce these results.
I like to push my barriers, seeking the best and doing the best (Obsessive Completion Distinction).
Previously I've examined some conversions available online and was able to reproduce their results using their parameters and StaxRip; not all information was available via MediaInfo (such as preprocessing) but the parameters were listed and I could reproduce their results with a little experimenting and tweaking.
Now a group has started to release conversions that have the following characteristics
1) Audio - no problem (easy to reproduce; the codec and bitrate are identifiable)
2) Video - that their bit rate the motion artifacts are minimal, whereas I get some artifacting on extreme motion
3) MediaInfo has the encoder information stripped (or not recorded at all) regarding the parameters of the x265 encoding.
This is more of a technical analysis so I can convert my videos to the best that I can create.
I know the rules regarding warez, and I understand that, but I would like to learn how to reproduce their results - purely an technical analysis and not promoting or proliferating warez.
I would like to know if I can state the name of the group (it could help); unless someone could assist me further with this endeavor.
Possibly the exclusion of the x265 encoder parameters could be a clue to the encoder the group is using.
Zones could be used and analysis/comparisons would not help.
Depending on the source you can do all kinds of filtering denoise, degrain, something here ,addgrain, so again you cannot compare your results as well. You can add grain only in dark areas etc. -
That's right, and even if you knew all the settings, it might not help all that much. Making very low bitrate encodings often requires some serious filtering in order not to get the artifacts you're noticing in your own encodes.
And I doubt they're using StaxRip, not that there's anything wrong with StaxRip. -
Start by shooting 24 fps progressive frames with low noise, shallow depth of field, and a stabilized camera. Rather than shaky, noisy, 30i or 60p camcorder video.
freeware x265 encodes with 10-bit color
By akrako1 in forum Video ConversionReplies: 13Last Post: 1st Jul 2018, 17:57 -
X265 encodes 0 frames
By smike in forum Video ConversionReplies: 4Last Post: 12th Mar 2018, 03:16 -
FFMPEG x265 10bit and virtualdub x265 10bit settings
By lilycarolyn in forum Video ConversionReplies: 11Last Post: 6th Jun 2016, 14:44 -
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 08:14 -
What is faster for x265 encodes??
By xenotox in forum Video ConversionReplies: 2Last Post: 26th Nov 2014, 02:13
