I want to encode some anamorphic DVDs that are in 720x576, so what command should you type in FFmpeg to get this squished picture to stretch out to the correct 16:9 ratio?
Results 1 to 9 of 9
You can specify the ratio using the -aspect option.
Or you may try to use exclusive codec syntax (x264/x265 case). Setting aspect in wrong place may trig unwanted libswscale behaviour.
Thanks, that's sorted it.
And keeps the file size down without me having to resize it in AviSynth.
The odd thing is, Mediainfo is reporting the 'Display aspect ratio' of the original VOB file as 2.40:1, yet it displays as 16:9 when played in VLC player (which it should be)Last edited by Master Tape; 7th Jul 2018 at 12:55.
What's even more bizarre, it actually plays in 2:40:1 when loaded into Windows Media Player (not that i use that anymore) but it does look wrong/squished.
So perhaps you need to follow pandy's advice and tell the encoder about the ratio. For example, using libx264
-x264_params sar=1:1.48
(that colon probably needs some kind of escaping, but I'm too lazy to figure it out!)Last edited by JVRaines; 7th Jul 2018 at 14:26.
It's not an issue in general, it still does what i want it to do by outputting to the correct 16:9 without affecting the resolution. Just thought it was funny the VOB played like that in Windows Media Player, but not in VLC.
FFMpeg cutting without re-encoding // AviDemux keep aspect-ratio info
By vpvaxn in forum EditingReplies: 6Last Post: 15th Apr 2017, 22:53 -
How to Change Aspect Ratio of MP4 Video Without Re Encode using ffmpeg?
By morsh in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2016, 04:08 -
Help with Aspect Ratio of Screen Captures Anamorphic Widescreen
By beanie168 in forum Capturing and VCRReplies: 13Last Post: 22nd Mar 2016, 16:24 -
Change MKV / MP4 aspect ratio for widescreen TV
By MisterNewb in forum Newbie / General discussionsReplies: 19Last Post: 17th Jul 2014, 13:02 -
Setting correct aspect ratio with AVStoDVD/ HC Encoder
By MovieMarathon in forum Authoring (DVD)Replies: 1Last Post: 23rd Jun 2014, 01:34
