Hello everyone!
I really dont like the idea of hdr, some things do not have an option without hdr and this should get worse over time. So I wanted to know, is there any way to "remove" hdr from a video? Or some way to "restore" the original video color without hdr? I think I'm probably talking nonsense, but if the method exists, it would be great for me.
I've recently found an interesting suggestion of Google to convert HDR to SDR using a LUT:
https://developers.google.com/media/vp9/hdr-encoding/
Search the page for:
"Converting HDR to SDR"
They do it for VP9, but it also works for AVC/HEVC. To be able to let it run, you must download the LUT file from:
https://storage.googleapis.com/media.webmproject.org/devsite/vp9/input/hdr/bt2020_to_b...9_example.cube -
That's interesting, I'm currently testing avs + DGToneMap. It seemed to me that the ffmpeg tonemap works better in certain aspects, but it seems to be much slower than avs +, I'm really in doubt about which one to use and which one really is better.
Which one does the best result these days? But I think it will depend on each source right? -
The LUT method doensn't seem to be faster than zscale unfortunately.
From my point of view results look very similar. Here are two examples at 1440p. The Original can be found at: https://hdrsamples.com/exodus-4k-uhd-hdr-sample-footage/
I've used the following commands to create those:
LUT example:
Zscale example:Code:ffmpeg -analyzeduration 10M -probesize 10M -i Exodus_UHD_HDR_Exodus_draft.mp4 -map 0:v:0 -map 0:a:0 -aspect 16:9 -pix_fmt yuv420p -vf scale=2560:1440:in_color_matrix=bt2020,format=rgb48,lut3d=bt2020_to_bt709_example.cube,scale=-1:-1:out_color_matrix=bt709 -c:v libx264 -preset fast -profile:v high -crf 18 -ac 2 -c:a aac -b:a 128k -y exodus-1440p-sdr-lut.mp4
Code:ffmpeg -analyzeduration 10M -probesize 10M -i Exodus_UHD_HDR_Exodus_draft.mp4 -map 0:v:0 -map 0:a:0 -aspect 16:9 -vf scale=2560:1440,zscale=t=linear:npl=100,format=gbrpf32le,zscale=p=bt709,tonemap=tonemap=hable:desat=0,zscale=t=bt709:m=bt709:r=tv,format=yuv420p -c:v libx264 -preset fast -profile:v high -crf 18 -c:a aac -b:a 192k -y exodus-1440p-sdr-zscale.mp4
Zscale with ffmpeg seems the best choice, compared the videos you attached, the LUT was worse with the brightness compared to zscale.
Dgtonemap in avs + failed, doing the test in this video the script became very slow and the output was a green screen, I tried to correct changing the input-depth and output-depth but it did not work. I should not know how to use the filter correctly.
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 13:31 -
How to convert "Still Image" to "AVC file" (like as Godzilla Blu ray Menu)
By ningnong132 in forum Video ConversionReplies: 2Last Post: 8th Sep 2014, 05:23 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53
