Attached a sample cut from a DV capture.
Any way to remove & reduce it? Thanks.
by connecting your vcr and video grabber to the same power source, usually this fix the problem
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
I was able to almost completely remove similar horizontal bars from an amateur Kinescope of a 1950s NFL game (only known capture of a 1950s NFL TV broadcast). Here is the "before/after":
https://www.youtube.com/watch?v=qx26T6WOZ_4
Here is the discussion where I provided details of how I did this work:
Bad 1950s Kinescope - Hopeless?
Your vertical bar is pretty subtle, so I don't know if my algorithms would be able to detect it.Last edited by johnmeyer; 7th Jul 2018 at 10:26.
VisualSubSync - Video Bar / Audio Bar / Text Bar
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 14th Feb 2018, 23:35 -
Vertical line spacing in ass subtitle file
By spopic in forum SubtitleReplies: 3Last Post: 21st Jun 2017, 03:07 -
Green vertical line on left side of the screen after filtering in Avisynth?
By Srivas in forum RestorationReplies: 2Last Post: 19th Feb 2016, 00:03 -
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 14:03 -
Active subwoofer without hum?
By miepel in forum Off topicReplies: 6Last Post: 2nd Nov 2013, 08:24
