Background ghosts in small squares ou Green screen in copy mode in Avidemux What can it be? (detail, only in the second part), inverted the test by putting the second video in the first part and the error continues only in the second part, only that went from green screen to ghosts.
Each part is a different video of 5 minutes with bitrate difference from one video to another of +/- 200 Kbps and audio bitrate the same. The audio formats are ACC and MP4 video. VLC gives me the following errors:
main warning: picture is too late to be displayed (missing 183 ms)
main warning: picture is too late to be displayed (missing 519 ms)
main warning: picture is too late to be displayed (missing 96 ms)
main debug: picture might be displayed late (missing 3 ms)
main warning: picture is too late to be displayed (missing 21 ms)
main warning: picture is too late to be displayed (missing 582 ms)
main warning: picture is too late to be displayed (missing 26 ms)
main debug: picture might be displayed late (missing 1 ms)
main debug: auto hiding mouse cursor
main warning: picture is too late to be displayed (missing 513 ms)
main warning: picture is too late to be displayed (missing 16 ms)
main warning: picture is too late to be displayed (missing 39 ms)
main warning: picture is too late to be displayed (missing 548 ms)
main warning: picture is too late to be displayed (missing 114 ms)
main warning: picture is too late to be displayed (missing 490 ms)
main warning: picture is too late to be displayed (missing 86 ms)
main warning: picture is too late to be displayed (missing 221 ms)
main warning: picture is too late to be displayed (missing 529 ms)
main debug: toggling resume
main warning: picture is too late to be displayed (missing 166 ms)
mmdevice debug: state changed: 0
When the video with a larger bitrate comes first, the second part has squares of background checks and small lapses of locking and when the video with smaller bitrate is in the first part, the second part has a green screen with small lapses of locking.
What could be wrong? (Avidemux tested Normal mode and last night version Windows 32bits, Tested also in XP compatibility mode of W7)
W7 sp1 32bits Directx 11//Dual Core Intel2180 2 Ghz - Bus speed 800Mhz//GA-945GCM-S2L//Memo Dual Channel 1GB+1GB 667Mhz//No video card//HD SATA 1x80GB + 1x160GB.
Sounds like a badly encoded source file.
@lordsmurf, Thanks for reinforcing the thought I already had, the curious thing is that if I "make a copy joining parts of only one video at a time" by dividing and discarding some parts and joining later, this does not happen. It only happens when together the two videos of different bitrate, divided or not. Other videos with less bitrate difference are copied together without any problem. ie, let's say the problem was with this video of higher bitrate and bad coding, if I cut some parts of it and join it and make a copy Voila, but if together it in the context with other videos the error happens.
camera for green screen
By DeeEmm8134 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Dec 2017, 22:12 -
Avidemux green screen on preview?
By lordsmurf in forum Newbie / General discussionsReplies: 7Last Post: 26th Feb 2016, 13:02 -
Green Screen and Screen Flickers On And Off
By Teac23 in forum ComputerReplies: 2Last Post: 9th Jul 2014, 11:57 -
Green Screen Help!
By billyjb26 in forum EditingReplies: 7Last Post: 14th Mar 2014, 17:18 -
AVIDemux to Join, Get Green Video
By ntallman in forum Newbie / General discussionsReplies: 7Last Post: 14th Aug 2013, 12:01
