1st, sorry if this is the wrong subforum - or if no Videohelp forum is appropriate.
Feel free to move this, or comment on more suitable sites / forums.
NOTE: We use ANTENNA, over the air for all TV reception. That's not likely to change.
I doubt we'd ever pay for Hulu, Netflix or similar services - with or w/o smart TV. It'd depend on several factors.
Our 10 yr old, non-smart Vizio TV (dumb?) went out. Might be able to replace a board, but on a 10 yr old TV...?
Anyway, my dilemma is *most* smart TVs' privacy policies (lack of privacy) are very invasive - LG, Samsung, Sony, etc.
From what I've read, if you don't agree to the entire privacy / TOS policy, many of the "smart" features won't work.
I need to find out which smart features wouldn't work and if there are reasonable options to record OTA shows; access & play content stored on a PC. Not sure why it's legal to totally brick the "smart" functions when you paid $100's or $1000's for, if you don't agree to most everything. If you buy a fridge, do you have to agree to allow their wireless adapter & camera to report everything you store or eat?
Yes, you can block in your router or by other means the outbound addresses smart TVs access, and stop them phoning home, but...
I'm looking for ANY helpful info on:
1) what "smart" TV features / functions typically stop working if you block most / all IP addresses they contact, where personal info or content viewed may be sent? We're both retired, partially disabled, so hiding use of illegal or "immoral" content isn't the issue.
2) what features (on smart TVs, that "regular" TV's wouldn't have) would *likely* still work, if you didn't agree to their policy(ies) that allow them FULL access to your use AND personal data - AND allows them or 3rd parties to use that data to deliver targeted ads?
It would still work as a "non-smart" TV, but I don't know if any features would work, other than similar to recent "non-smart" TVs?
E.G., setup menus (cable or antenna, etc.), adjust colors & picture; sound settings, etc.
The other big questions are, what (good) options exist
3) to record from a non-smart TV to a programmable digital DVD recorder / player?
I've not seen many DVD recorders for sale. We had one when OTA was still analog. It wasn't too bad.
4) If I don't agree to smart TV's policies, could the TV likely still connect to our home wifi, AND access / play content - either D/L'd to a PC, or access *from the TV*, content recorded w/ a TV tuner card in a PC ? (don't have a TV tuner card now).
If certain smart TV features didn't work, BUT I could still access a PC via wifi, & have a reasonable way to "see" & select what's on the PC, I might not care if a smart TV - ITSELF - had direct internet access via wifi.
5) Other acceptable methods I haven't thought or heard of (whether Smart or dumb TV)?
I think *ONE* problem of recording or D/L'g on a PC, then accessing VIA a TV "menu" the content on the PC. The software to see on a TV "menu" - what's on the PC, even IF you can access the PC via wifi, is or can be a problem, so I've read. Sure, it'd be nice to have (easy, quick) way to tell the PC and / or a DVD recorder what to record.
I'd consider using both a DVD recorder (or DVR *not* requiring subscription) for OTA TV content, and D/L'g to PC some internet content - if the PC is accessible via a TV "menu" or list. Burning PC content to DVDs & putting in a DVD player is a pain.
I'm using Linux on my desktop w/ a very customized partitioning scheme (dual boot w/ rarely used Windows), on 2 HDDs, & I'm installing 'Nix on our old laptop. That gives an idea of my general ability. But there are likely new TV or D/L / streaming recording & playback technologies (or hacks) I'm not aware of.
I'd appreciate any "pointing" in the right direction.
Don't get a DVD recorder unless you desperately want recordings on DVD. They are uncommon because nobody makes DVD recorders for the N. American market at this point. The last manufacturer to do so, Funai/Magnavox, appears to have recently discontinued production. If you really want a DVD recorder, you will have to buy a used or refurbished unit.
I would suggest that you look at the SiliconDust HDHR5-4US/HDHomeRun CONNECT Quatro 4-Tuner. It is a network device which can be attached to one of your router's Ethernet ports or directly to a PC's Ethernet port. If attached directly to a PC, only the PC will see the tuners. If attached to the router, all PCs on the network can see the tuners. There are drivers and software for Android, Linux, OS X and Windows. SiliconDust's DVR service is $35/year and includes software and guide data. You could also use MythTV and get guide service from SchedulesDirect for $25/year. I use Windows and either NextPVR or Windows Media Center, so I can't help you with MythTV. SiliconDust does have a decent user forum.
It is possible to wirelessly stream recordings stored on a PC (I've done it) or NAS to a DLNA device, but a wired network is recommended and probably works better for many users. I've had better results wirelessly streaming files to a PC (connected to a TV via HDMI) than directly to a smart TV. I haven't tried simultaneous streaming recordings to multiple devices.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
10 years is a good lifetime for modern TVs (gone are the days when CRTs lasted for decades). Spend a little more than the cost of a repair and get a much higher quality and larger new TV.
Note: Most new TVs don't have VGA inputs anymore, but you can use an DVI to HDMI or USB to HDMI adapter if your PC/laptop doesn't have HDMI output.
I'd appreciate any "pointing" in the right direction.Last edited by lingyi; 7th Jul 2018 at 19:57.
Thanks for helpful comments. I apologize for long time getting back. It's been a rough year for us, health wise. I appreciate people taking time to answer thoughtfully. I didn't intentionally wait this long.
One obstacle may be how we connect a smart TV to the "recording" PC - wired vs. wifi. Thanks for links to various technologies.
I've skimmed some of the pages & products, but it'll take a good bit of reading before I know some of what I don't know, on follow-up questions, not answered by the resources & finding articles. I know I'll have some questions. -
Hope all is well now and into the New Year!
Check out the new Fire TV Recast, it's new but sounds like it would suit your needs. https://www.amazon.com/Fire-TV-Recast-over-the-air-DVR-500GB-75-hours/dp/B01J6A6H74/re...k+recast&psc=1 -
Each brand of TV offers something different, I have an LG smart TV, it
has access to the channels at xumo.com through something it calls Channel Plus
There is an on/off switch you have to agree to - then Channel Plus is available.
and LG will take a note of which of those channels you watch. There are some useful
news/current event channels we turn on in the morning. Except for that
and the occasional "B" movie, I hardly watch it. But it's there.
The other odd thing is that I experimented with the TV's network setup and put in AdGuard
DNS servers - this had the affect of stopping almost all the ads in Channel Plus. It tried to play them;
instead of the ads showing up we got tiny pauses every 6 or 7 minutes.
There's another setting, Live Plus, which turns on the LG automatic content recognition system -
I left this off. I think as long as this is off, anything over the antenna or local media files should be private.
I understand your privacy concerns; my TV does not have a camera nor a microphone, so one less
thing to worry about there.
Everybody's access to "content" is different, we recently cut the cord, dropped cable
TV & DVR. We tried antenna but we are in a location where the reception was not reliable
so we have also dropped that option for now. We make do with Channel Plus, Amazon Prime
and whatever free stuff is on the Internet (Tubitv.com, Kanopy, Film detective,etc,etc) and
media files I have on my own PC. We've got used to it, I don't miss cable TV at all.
The router I have is literally right next to the TV, I tried Ethernet and WiFi, and WiFi works
best for me. I could only tell when streaming from my Windows 10 PC at rates greater than
50 mbit/s and I would get a short pause as it buffered perhaps twice a minute using Ethernet.
With WiFi problem was alleviated.
I posted about it once before because I thought it odd that WiFi was able to sustain
a steadier throughput. Perhaps the Ethernet cable needs to be Cat 6. One of these days I'll buy
one and retest
I can play media from my PC through the network to the TV in at least three different ways.
I can right click the file in Windows and select "cast to" (this works best in Windows 10
although Windows 7 and 8 had some support)
I can initiate the playback from the TV by connecting to the PC's media server and selecting
the file from the TV's menu. This also works in Linux, you just have to have a media server installed
(I used miniDLNA) Thirdly, I can use my android phone to start the playback using various apps that
are free or for a small cost. Similarly I can stream free content from the internet by accessing it
from my phone and casting it to the TV. This is the advantage the network has over an HDMI
connection, it's so flexible.
Good luck with your choice, either a TV or TV and streaming box. Even with box you still have privacy
issues.
https://www.consumerreports.org/privacy/how-to-turn-off-smart-tv-snooping-features/Last edited by davexnet; 28th Dec 2018 at 21:24.
for linux pvr recording, see here - https://kodi.wiki/view/PVR_recording_software
H265 - Any tool to make a "smart rendered" cut?
By Seeker320 in forum EditingReplies: 2Last Post: 4th Oct 2015, 20:48 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
Why 16:9 "Original" & 16:9 "Full" settings on Blu-Ray player....?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Apr 2015, 08:13 -
Can Someone Recommend a Blu-Ray Player that can read "BD-R" & "DVD-R" ?
By THEBDC in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Mar 2015, 17:03 -
Good HDD DVD recorders with "Flex Time" like features.
By FromPartsUnknown in forum DVD & Blu-ray RecordersReplies: 19Last Post: 4th Oct 2013, 10:28
