Results 1 to 14 of 14
  1. Member koberulz's Avatar
    Oct 2006
    Australia
    All MediaInfo has is this:
    General
    Complete name                            : K:\GOPR0090.MP4
    Format profile                           : Base Media / Version 1
    Codec ID                                 : mp41 (mp41)
    File size                                : 2.24 GiB
    And another with even less info:
    General
    Complete name                            : K:\GOPR0218.MP4
    File size                                : 3.73 GiB
    What's happened here?
    Aug 2010
    San Francisco, California
    Obviously the streams (if any) are unreadable. Open the file in a byte editor and check if it's mostly 00s or FFs.
  3. Member koberulz's Avatar
    Oct 2006
    Australia
    There are quite a few 00s, but I'm not sure what's typical. Wouldn't be a large percentage though overall, although the second line is 00 all the way to 1D.
    Aug 2010
    If you want to dig into it, you can follow the atoms (chunks) using the offset values and see what's up. This page has explanations and an example.
  5. Member koberulz's Avatar
    Oct 2006
    Australia
    I'm not sure what 99% of that means...the ASCII just says ftypmp41, mp41.1.*mdatGPRO, HD5, something about a HERO5 Black.
    And actually scrolling down, a huge chunk at the end is just 00s. It's a fair way down though.
    Aug 2010
    Search for the text MOVI. If the zeroes come after it, then there is no media content.
  7. Member koberulz's Avatar
    Oct 2006
    Australia
    It occurs 8 times. The last is maybe 3/4 of the way through the non-zero content.
    Aug 2010
    Then there's a good chance there's some video in there. Search the forums for "MP4 repair" and you will find a few software tools.
  9. Member Cornucopia's Avatar
    Sounds like someone has already (incorrectly) tried to recover some files, and concatenated.
  10. Member koberulz's Avatar
    Oct 2006
    Australia
    I have no idea what's gone on. Someone gave a USB drive to someone else because they couldn't open it, the someone else couldn't open it either so they gave it to me.
  11. Member koberulz's Avatar
    Oct 2006
    Australia
    Do you have any specific suggestions? Searches just show sites of questionable integrity plugging their own software.
    Mar 2008
    Is this file from a camera? Do you have a working media file from the same device?
    https://www.videohelp.com/software/Video-Repair-Tool
    It's payware, but there is a demo mode you can check if it works and it's supposed to
    restore 50% of your file for free.
    There is also untrunc in Linux, you can read a little more about it here:
    https://github.com/ponchio/untrunc
  13. Member koberulz's Avatar
    Oct 2006
    Australia
    No, I don't have a working file.
    Aug 2010
    There is a whole section of VideoHelp devoted to repair tools.
