I have a computer with Linux Mint 18.3 and purchased a "Huawei LTE Wingle E8372" mobile broadband wi-fi adapter from the local Telstra (Australia) store. I know little about Linux commands and cannot get the computer to recognise the adapter. I tried to install modeswitch, but tells me that it is already installed. Installation on Windows works fine as it has a program installed on the adapter for Windows. Does anyone know how to install this adapter in Linux? Help would be much appreciated.
Results 1 to 10 of 10
AnonymousGuest
Hi
Maybe this will work for you:
https://gist.github.com/guseppiguliano/614055d0bc260f5ea305d71439a03790
Or this:
https://askubuntu.com/questions/790893/huawei-usb-4g-modem-not-detected
Make sure that your system is up to date and maybe it needs the latest kernel updates for this modem to be recognized
sudo apt update
sudo apt upgrade -
You may have better luck here: https://forums.linuxmint.com
BTW, in Mint, don't use apt upgrade. Mint is Ubuntu based (unless it's LMDE) but it's not Ubuntu. Using apt upgrade can cause things to be pulled in from the Ubuntu repos that shouldn't be in a Mint system. Problems this can cause are hard to diagnose. -
AnonymousGuest
@hoser rob
Ubuntu AND mint use the same official ubuntu repo, so there is nothing wrong with apt upgrade -
AnonymousGuest
You are right about exact repo's, Mint uses it's own repo in combination with ubuntu repo
This is in a standard install always the case, so why would that be a problem? If it would be a problem why will the developer of mint put it in the software sources?
I'm only try to help the OP to install the device, so start with a up to date system will prevent al lot of unnecessary problems
[edit] i'm relatively new to Linux and have about 2 year experience, so i'm not a Linux guru but i do like to learn something if i'm mistaking.
isn't helping much, neither to the OP or meyou don't know what you're talking aboutLast edited by Anonymous19484; 7th Jul 2018 at 09:30.
AnonymousGuest
@hoser rob
The master has spoken..
I never asked you to help me!
I personally used sudo apt upgrade several times on my mint 18.3 machine and never had a problem.
Funny.. we are bitching around here wile the OP never responded back...
So this has to stop.Last edited by Anonymous19484; 15th Jul 2018 at 13:39.
Thanks everyone, but the reason I have not responded earlier is that I fail to see an answer to my problem. Also, I have had a hard drive problem on my Linux ultrabook so decided to take it to the store I purchased it as it is under warranty, which was a very, very bad mistake as they have 'damaged' my computer and thrown away the original packaging and deny responsibility, so at present my mind is elsewhere until all this is sorted.
Hi ColourOz...
While Telstra does not officially support Linux for its dongles...
It's not impossible to set up.
head on over to the Telstra crowd support page here for a possible solution.
https://crowdsupport.telstra.com.au/t5/Mobile-Broadband/Linux-support-on-USB-mobile-br...and/m-p/103678
Not able to access HDD in Ubuntu or Linux Mint
By visionman in forum LinuxReplies: 6Last Post: 14th Jun 2018, 06:26 -
if you've downloaded linux mint recently it includes a trojan backdoor
By aedipuss in forum LinuxReplies: 9Last Post: 1st Mar 2016, 20:23 -
Handbrake, Intel QSV, Linux Mint
By hogger129 in forum Video ConversionReplies: 6Last Post: 22nd Aug 2015, 06:44 -
aTube Catcher on a computer running Linux Mint?
By gastrof in forum Newbie / General discussionsReplies: 6Last Post: 4th Mar 2015, 08:48 -
Trying to connect Linux Mint to Xfinity WiFi on a Netbook
By dfisher052 in forum LinuxReplies: 10Last Post: 12th Jan 2015, 15:35
