Subtitle Workshop 2.51 fails to convert multiple SRT files from 23.976 fps to 25.000 fps
I have about 100 SRT files that were designed to run at 23.976 fps. I want to convert them to work with an associated set of video files at 25.000 fps. Using Subtitle Workshop 2.51's GUI, I successfully converted a test file to 25.000 fps (and verified that it worked correctly with its associated video). But I was unable to perform the same conversion across multiple SRT files. First I tried using Subtitle Workshop's [Tools.Batch Convert...] menus, but the new SRT files had the same timings as the old ones -- no matter what I did. Next I tried calling "SubtitleWorkshop.exe" via the below-shown batch file. My batch file successfully generated [new.srt] from [old.srt], but did not update [new.srt]'s timings. Very frustrating. Can anybody please help me out?
@ECHO OFF
Set AppPath="C:\Program Files (x86)\URUSoft\Subtitle WorkShop\SubtitleWorkshop.exe"
:: <AppPath> /CONVERT(<Inpf>/<Outf>/<OutFmt>/<InpFps>/<OutFps>
%AppPath% "/CONVERT(old.srt/new.srt/SubRip/23,976/25,000)"
Note: I am using Subtitle Workshop 2.51 becuz VirusTotal reports malware in all of the more recent versions.
Results 1 to 1 of 1
How to batch translate multiple SRT files
By demowolf in forum SubtitleReplies: 2Last Post: 22nd Jun 2018, 00:02 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 05:01 -
How do I convert HD NTSC footage into HD PAL - what frame rate is best ?
By Bansaw in forum EditingReplies: 18Last Post: 21st Nov 2014, 16:27 -
SRT and frame rate issue
By John2K in forum SubtitleReplies: 6Last Post: 19th Jan 2014, 00:24 -
How to Discover the Correct Frame Rate From Subtitles ( srt,ssa, etc. )?
By devilcoelhodog in forum SubtitleReplies: 18Last Post: 2nd Dec 2013, 13:33
