hi everyone!
First let me apologize for the thread title, i don't know how to call this, i recorded some videos with my phone but unfortunally forgot to increase the video bitrate beforehand, it resulted in some videos where there's more "movement" having a "jumpy/flicking" background, is there a way of atenuating this effect/artifact"?
What i tried so far:
1- Denoising- made footage look worse
2- duplicated the video on 3 layers and made each layer start 1 frame later than the previous one, gave different opacity levels to each thinking it would blend some frames and atenuate the effect, didn't work
3- in premiere pro select frame blend but it didnt work
I know the "effect/artifacts" cant be removed but i was hoping there would be a way of decreasing the level of the artifacts.
here's a small sample
https://www.dropbox.com/s/cbw136605x35cc0/SAMPLE_4K.mp4?dl=1
Thank you
I love it when a plan comes together!
This isn't perfect but you may consider it an improvement (half size to make it easier to view).
I'm having trouble uploading. I'll try again later.Last edited by jagabo; 4th Jul 2018 at 12:30.
Hi Jagabo, thanks for the advice.
I also thought resizing to 1080p would get rid of the "artifacts" but it doesnt... i think it might be better to reshoot the whole thing with higher bitrate...lesson learned...take your time to check your settings...
Once again thanks for your help.I love it when a plan comes together! -
Resizing will not get rid of the artifacts. I just did that because I can't view a 4K video at full resolution. And the upload would be smaller. The upload was the result of using the first frame as a base and overlaying the moving parts of the video over it. Then a strong temporal filter was applied. There are some weird motion artifacts -- like the tree at the top of the top center of the frame which jerks around and flickers. Obviously, reshooting is the better solution.
You could reduce the frame rate to match the slow peripheral updates, then interpolate and matte the central area into it.
My opinion: Could be you are using slower storage SD card and your phone might be buffering (not being able to keep up)
LAME.exe's "bitrate around" and -V "'s relation, and -k option good or bad?
By sommers in forum Newbie / General discussionsReplies: 8Last Post: 14th Jun 2017, 04:18 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
Is there a way to "Paste" MPC-HC shader effect to a video?
By Unknown01 in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2015, 16:30 -
How to get rid of "little blocks" effect of DVD-Video
By provato in forum RestorationReplies: 53Last Post: 16th Oct 2014, 13:11 -
Removing Commercials with "Video To Video".....a Disaster
By Ogilvy in forum EditingReplies: 10Last Post: 27th Jul 2014, 15:47
