I'm importing what should be a 2:08 m2v into Encore, but it's importing at 1:57. Windows also says it's 1:57.
Created in HCEnc 0.28. When I play the AVS input in MPC-HC it runs the full length of the video.
MediaInfo:
Code:General Format : MPEG Video Format version : Version 2 File size : 7.37 GiB Duration : 2 h 8 min Overall bit rate mode : Variable Overall bit rate : 8 237 kb/s Video Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=2, N=14 Duration : 2 h 8 min Bit rate mode : Variable Bit rate : 8 237 kb/s Maximum bit rate : 9 000 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.795 Time code of first frame : 00:00:00:00 GOP, Open/Closed : Open GOP, Open/Closed of first frame : Closed Stream size : 7.37 GiB (100%)
There was a .xmp and a .mpgindex file in the folder with the same name as the video. I deleted those and re-imported and it's working fine now - I accidentally set the work area incorrectly when I exported from Premiere the first time, obviously those files were flagging it as that length in Encore even with the corrected video.
UHD Bluray Video Mediainfo - From the Alleged AACS 2.0 Crack
By KarMa in forum Latest Video NewsReplies: 2Last Post: 27th Jul 2017, 04:24 -
VOB file displays "1 sec" length, is actually 29mins, plays full length but
By neonnebula in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2015, 21:12 -
Why MEDIAINFO don't report if video is NTSC or PAL?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 29th Oct 2014, 12:07 -
MP4 files from Handbrake: mediainfo says "delay relative to video: 67ms"
By dave in or in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2013, 03:59 -
Nothing I Have Opens This Video (MediaInfo incl.)
By hech54 in forum EditingReplies: 7Last Post: 6th Sep 2013, 16:55
