  1. Hello everyone,
    This is the main M3U8 and the 360 m3u8:
    http://cdn-vod.tvpublica.com.ar/out/2018/06/05/SJy2VL4xX/main.m3u8
    http://cdn-vod.tvpublica.com.ar/out/2018/06/05/SJy2VL4xX/360.m3u8
    These are the original webs:
    http://www.tvpublica.com.ar/articulo/manes-en-cada-noche/
    https://vody-embed.tvpublica.com.ar/v/SJy2VL4xX
    I tried to use hlsdl and I was able to get the entire .ts but it seems to be still encrypted, as it is detected as data and won't play in any media player/editor/etc.
    I'm a GNU/Linux user so feel free to suggest command line programs and, even better if you can tell me a way to download it that doesn't involve proprietary software.
    Any help will be appreciated
  2. you can use streamlink
    streamlink --http-header "Referer=https://vody-embed.tvpublica.com.ar/v/SJy2VL4xX?" --http-header "User-Agent=Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36" --http-header "Origin=https://vody-embed.tvpublica.com.ar" "https://cdn-vod.tvpublica.com.ar/out/2018/06/05/SJy2VL4xX/main.m3u8" best -o video.mp4
  3. Hi vidder ,
    @brunomoreno71 : thanks
    livecli ( update of streamlink ) .
    you can select the quality , by replacing 'best' :
    Available streams: 240p (worst), 360p, 480p, 720p, 1080p_alt, 1080p (best)
    Cheers .
    JE SUIS CHARLIE !!!
  4. Hey thanks for the prompt reply!
    I used streamlink and it worked just fine, but it seems that the video is flawed. It looks jerky and faulty. Perhaps they compressed/encoded it in a wrong way? Anyway the audio is perfect.
    Thank you.
