I really like using MPC-HC for watching movies. Since it's no longer getting updates is there any way i can manually update LAV filters.
MPC-HC 1.7.17 with LAV 0.72 was released recently, there is still some basic maintenance. Personally, I've deleted the internal LAV filters from the MPC-HC folder and use the external ones like flashandpan007 suggested. Not all formats are activated in the internal ones and it is easier to test nightlies this way + then all DirectShow apps can use them.
I use MPC-HC and after installing new LAV filters perform manually copy from LAV folder to MPC-HC folder - it works but also frequently checked that without doing this latest installed LAV is used by MPC-HC instead internal one.
Thank you so much for your replies. I finally have the latest version of LAV filters!
Installed Codecs and LAV Filters
By Nitobert in forum Video ConversionReplies: 4Last Post: 30th Jan 2017, 05:29 -
Dates of LAV filters
By jgg in forum Software PlayingReplies: 6Last Post: 27th Jan 2016, 15:02 -
Do I need LAV filters?
By Yanta in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2015, 05:01 -
MPC-HC with internal LAV Filters: play YUV video file?
By flashandpan007 in forum Software PlayingReplies: 10Last Post: 3rd Aug 2014, 13:43 -
Embed subtitles with lav filters?
By dude112 in forum Video ConversionReplies: 3Last Post: 22nd Sep 2013, 09:33
