I want to be able to downscale some videos, mainly SD footage which was recorded from a HD channel (upscaled)
Is there any good script that simply downscales the resolution without adding anything else (such as sharpening, edge enhancement, ect)
IMHO Spline34 or Spline64 - personally prefer spline resizers over other (most other resizer is build on principle windowing Sinc or windowing function itself and ringing is unavoidable - you can simplify that they approach is objective bandwidth/frequency not vision).
http://avisynth.nl/index.php/Resize
https://en.wikipedia.org/wiki/Spline_interpolation -
I've heard good things about Spline. I was using BiCubicResizer but just entering the resolution i wanted it in and nothing else, but then again i don't know what else these resizers add when processing.
I've also just found out you can downscale/upscale in FFmpeg aswell (which i use to encode the .avs file) Don't suppose anyone knows if you get any artefacts that way aswell? -
"Best" depends in part on your source and whether you are upscaling or downscaling. Sharper isn't always better.
When I'm looking for a sharpening resize I usually use Spline36Resize(). It gives sharp results with minimal oversharpening halos, aliasing and moire artifacts. But when I'm downscaling a very sharp source I usually use BilinearResize(). That gives a more natural look without creating or exacerbating oversharpening halos, and the least moire artifacts. When upscaling SD to HD I usually used nnedi3_rpow2(), sometimes preceded or followed with a mild aWarpSharp() and Sharpen(). That's best at retaining sharp edges without creating aliasing artifacts and oversharpening halos. -
I think that quality of resizers are comparable especially on open source as they frequently share same code with some small modifications. Ffmpeg may deliver marginally lower quality due a less predictable behaviour - there are some issues in signal path related to color space conversion and quantization range - Avisynth on other way is very reliable on this as everything is explicitly controlled by you - no magic in behind (ffmpeg may call rescale silently and well it is written especially those older parts by people that don't care too much about accuracy of conversion - this is my very personal opinion about ffmpeg - unless you not doing research and you are not videophile purist then ffmpeg should be fine but if you need bitexact perfection then probably Avisynth seem to be correct choice).
Choosing a resizer with MeGUI
By pooksahib in forum Video ConversionReplies: 6Last Post: 15th Mar 2018, 04:37 -
[MPC-HC (MPC-BE)] Can't change resizer: same output for each resizer
By rqqt in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2016, 11:07 -
Is it wrong to encode with a resizer in MeGUI?
By TeNSoR in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jun 2014, 15:34 -
avisynth - How to write avisynth script for rgba overlay
By moelover in forum EditingReplies: 3Last Post: 13th Apr 2014, 12:24 -
Photo resizer
By nic2k4 in forum MacReplies: 4Last Post: 28th Mar 2014, 09:10
