I am looking for a software that can allow me to edit my phone number in the video (recorded with a smartphone). The video lasts less than 15 seconds so I was hoping I could just edit every picture (frame by frame) (I know there would be alot of frames) but I don't know what software would be good for that. Any help/deas please?
Thank you!
				Results 1 to 9 of 9
	What you should understand is that your video is NOT composed of frames that have object layers - such as your face & body, the background, your phone, any text on it, a tree, dog, etc - unless you had a very specialty $$$ camera with tri-scopic (or more) depth sensing, machine vision with AI, and more.
 The normal cam just records (not-so-) simple PICTURES of DOTS of color. You don't edit dots with a text editor.
 If you have a spot on a recording where there is the IMAGE of a phone with the IMAGE of numbers on it, you could in an editor create a separate layer to mask and another layer to overlay different numbers, and those layers may need to be warped, and animated, to match the perspectives of the original image layer.
 All of this requires a powerful, full-blown NLE with FX/processing & compositing capabilities. Or, if you go the frame decomposition route, a similarly powered photo editor. Possibly use a 3D modeling/rendering/anim software to assist.
 You might be able to get away with low/no cost options (avidemux, vdub, avisynth, gimp, resolve), but what you gain in economy, you lose in time spent in setup and/or quality. If you are serious about this, we are talking about using the bigger apps: vegas, premiere, after effects, nuke, fcp, edius, media composer, maybe resolve pro, etc. And photoshop.
 And even then, it isn't easy. Much prep and manual work involved.
	So if I'd ask someone to do that as a service for me (sine it seems like I can't handle that) , how much would that cost me?
	I'm having trouble understanding how the phone number is in the video. You have a series of numbers in a certain location and you want to completely remove them? Use a logo remover. It'll leave a blur.
 You have a series of numbers in a certain location and you want to replace one or more of the numbers and leave the numbers in the video? Edit the numbers once and replace them throughout the entire video with your edited version.
 A sample, or at least a picture, might be helpful.
	The whole Q. is rather confusing. Well it is for me.
 So let's slow this down.
 Is the number already in the video and you want to change it or even get rid of it ?
 Or
 Do you want to put the number in to the video ?
 The second one is quite easy to accomplish.
	Put a color-filled box over the old number, then create a PNG w/background transparency for the new number.
 *Oh, wait, if you only have a single timeline then you cannot composite.
	Easy to accomplish unless you want it to look natural (IOW, part of the original recording).
	Oh, I'm just making an assumption. Could be wrong.
  Frame Rate, Bitrates ans Frame by frame comparisonBy novreis in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2018, 18:40
  Frame by frame editing - Premiere Pro, Sony Vegas, or ???By Zoltan Losonc in forum EditingReplies: 60Last Post: 19th Aug 2016, 16:30
  How to find out frame exposure time in a variable frame rate .mov file...By bananas100 in forum EditingReplies: 5Last Post: 24th Oct 2014, 20:18
  Frame by frame timeline editing?By ShakeIt in forum EditingReplies: 6Last Post: 9th Aug 2014, 13:10
  Editing video frame by frame - less obvious results?By Free2bme in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jul 2014, 10:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
