I have a Hauppauge Colossus and I am trying to capture 640x480 NTSC video. The only input options within the Hauppauge Capture software are PAL resolutions and frame rates (480x576i, 1920x720, 640x360, 25fps, 50fps, etc.) There is no option within the software to select NTSC. Has anyone run into this problem before? The card supports both PAL and NTSC signals.
Screenshots: https://imgur.com/a/gIdqPUu
720x480 is NTSC resolution. Output Resolution set to "Source" should get you 720x480 with an NTSC source. With the output frame rate to "Source" so it should capture 29.97 fps.
There's not much to do but then I can't do much anyway.
Hauppauge Colossus HD-PVR
By SHS in forum CapturingReplies: 440Last Post: 9th Jul 2018, 05:40 -
Anybody who uses Hauppauge HD PVR 2 or Hauppauge Colossus 2?
By OS_Man in forum CapturingReplies: 14Last Post: 10th Jun 2018, 12:43 -
Hauppauge Colossus Crashing PC
By skatingrocker17 in forum CapturingReplies: 7Last Post: 28th May 2018, 09:52 -
Hauppauge Colossus or Hauppauge Colossus 2? Which to get?
By harky in forum CapturingReplies: 26Last Post: 8th Apr 2016, 12:38 -
Hauppauge Colossus
By fooledagain in forum CapturingReplies: 2Last Post: 10th Dec 2014, 15:00
