You converted the video at least once before loading it into cinelerra ... most editors in Linux don't have a stream copy option. Is there some reason you couldn't just load the video into cinelerra? ANd if so, why use an editor that requires so many steps before loading? Either of the preceding apps you used could have buggered up the sync.
That's why I asked which version he is using. Cin-CV and HV are QT based, will not accept most file formats and transcoding is usually the only option, whereas Cin-GG 5.1 is ffmpeg based and will accept almost anything ffmpeg can read, so raw camera files straight on the timeline is an option.Is there some reason you couldn't just load the video into cinelerra?
Phones usually record VFR (variable frame rate). This is a frequent source of problems if you're trying to edit. Usually you need to convert to CFR first, although some editors now have got slightly better at handling VFR footage (converting to CFR first is still the most reliable, by far). Not sure how good cinelerra or pitivi or winff is at handling it. ffmpeg itself will usually copy the timecodes over if converting - if the output format supports VFR timecodes
[ Manjaro ] Problems with Cinelerra 5.1 under Manjaro.
By Lehmeier in forum EditingReplies: 6Last Post: 9th Mar 2018, 09:29 -
Need help using Cinelerra Motion for image stabilisation
By DeJay in forum LinuxReplies: 15Last Post: 28th Jun 2017, 08:38 -
Cinelerra video editor [Linux]
By racer-x in forum LinuxReplies: 4Last Post: 13th Apr 2017, 02:37 -
VirtualDub audio out of sync, other video players all in sync
By a1s2d3f4 in forum Newbie / General discussionsReplies: 7Last Post: 11th Apr 2016, 22:36 -
How to 're-sync' and out-of-sync video?
By tkmops in forum Video ConversionReplies: 10Last Post: 18th May 2014, 13:58
