Objective: convert old 8mm tapes to DVD
Equipment: DVD Recorder- Panasonic DMR ES20
Camera-SONY Tr22 handycam 8mm
Problem: Camera plays, image lines through Panasonic fine, plays on TV, Panasonic acts like it records, shows "REC" icon on LCD and the counter moves, (leaves a data burn on the dvd) but after recording it will not finalize (or play) and claims there is no data on the newly recorded DVD.
I recently recorded a MiniDv w/o issue with this Panasonic recorder (except the MiniDv camera had known audio issues) and the recording was just to check the functionality of the Panasonic recorder and it worked.
This project is turning into an utter nightmare all equipment has been replaced and broke at least once so far this month, nothing seems to work, frustration is reaching the stratosphere, all I want to do is convert my old MiniDvs and 8mm’s and be done with it.
PLEASE HELP
Have you considered hiring someone with the equipment and expertise to preserve your videos? It may be worth leaving behind the frustration behind.
Yes, I did consider until I found what it would cost to convert a combined 42 (8mm and MiniDvs) tapes, I just do not have that kind of cash laying around and I do have the equipment, if I could only get it working.
What input connections are you using to connect
The handycam to the DVD recorder ?? And have you
Tried connecting the camcorder to the other connectors on the recorder ?? -
I have been using the input in front "In 2" b/c it is easy to get to and it worked for the MiniDV, but good idea I will try another input in case that is a digital-only input.
From what I researched, this Panasonic model has no problem with recording the 8mm format.
THANKS
considering options for converting 8mm & hi 8mm to digital
By glen_s in forum Newbie / General discussionsReplies: 57Last Post: 21st Feb 2024, 15:52 -
Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 7th Oct 2017, 11:34 -
Cropping Videos is a Nightmare
By Muze Twelve in forum Video ConversionReplies: 35Last Post: 24th Dec 2015, 04:20 -
Beginner's new nightmare - help d:
By santiagoartemis in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2015, 11:41 -
Another Nightmare Disc
By hech54 in forum Authoring (DVD)Replies: 14Last Post: 2nd Aug 2013, 07:44
