Results 1 to 9 of 9
    Jun 2005
    Vermont
    It seems when I make a DVD, at the end instead of ending it starts over again. I've tried everything I can think of to stop it from doing it, but nothing seems to work including turning off everything in the DVD menu as I do not use the DVD menu. Any ideas?
    I'm using ConvertXtoDVD4.
    Mar 2008
    Do you have a repeat program selected on the DVD player?
    Apr 2003
    If repeat program is disabled on your dvd player:
    I have ConvertXtoDVD 7, so your layout may be different. At EDIT MENU section, I chose NO MENU. Then I went to DEFAULT SETTINGS --> MENU OPTIONS and made sure LOOP PLAYBACK was unchecked. Burned an ISO and loaded it; played thru only once. I went back in and checked LOOP PLAYBACK and burned and loaded another ISO. Playback looped as expected.
    Jun 2005
    Vermont
    Loop is NOT checked. In fact nothing is check in menu. Have played on 2 different DVD players and 2 different players on computer (VLC & Potplayer) & they all repeat the video.
    Apr 2003
    I have reloaded ConvertXtoDVD 4 on my system and my DVDs do not loop. I downloaded and installed the last version for VSO Software (Version 4.2.0).
    I am out of ideas as to why your DVDs keep looping playback
  6. Member Backpain's Avatar
    Oct 2009
    Go to VSO website and report a bug to them and see if you get some kind of response from them.
    If it feels good, do it.
    Mar 2008
    If the OP is interested in looking at this in a bit more detail, you can use the program IFOedit and this guide
    to see what post commands are in the PGC command table
    http://atr935.blogspot.com/2013/06/pe-looping-dvd-video-on-dvd-disc.htm
    Easiest way to proceed would be to copy the Video_ts folder from the DVD to your computer HDD
    then follow the guide
    Jun 2005
    Vermont
    I just installed the program on another computer and still get looping. I also had an older version 3, installed that and get looping. Looking for a different DVD converter.
    Mar 2008
    AVStoDVD remember to set PAL or NTSC in the preferences, it defaults to PAL
    Can you post the IFO file to the thread and i'll take a look at it (VTS_01_0.IFO from the video_ts folder)
