Hi
I want to upload a video stream (from a file) to remote server using ffserver feed. I'm using as simple configuration as possible. So ffserver.conf is defined as following (relevant part):
File I'm trying to upload has following properties:Code:<Feed feed1.ffm> File /tmp/feed1.ffm FileMaxSize 100M ACL allow 127.0.0.1 </Feed> <Stream test1> Feed feed1.ffm Format mpeg VideoCodec libx264 AudioBitRate 32 AudioChannels 1 AudioSampleRate 44100 VideoBitRate 128 VideoBitRateRange 128-1024 VideoBufferSize 40 VideoFrameRate 25 VideoSize 640x480 VideoGopSize 12 NoAudio VideoQMin 1 VideoQMax 15 </Stream>
I'm trying to upload by running following command:Input #0, avi, from '01-20180608082004.avi':
Metadata:
encoder : Lavf56.40.101
Duration: 00:06:31.81, start: 0.000000, bitrate: 510 kb/s
Stream #0:0: Video: mpeg4 (Simple Profile) (FMP4 / 0x34504D46), yuv420p, 640x480 [SAR 1:1 DAR 4:3], 505 kb/s, 27 fps, 27 tbr, 27 tbn, 27 tbc
ffmpeg -i 01-20180608082004.avi http://localhost:8090/feed1.ffm
During the upload I'm getting a lot of messages like this:
And when I'm trying then to download the file http://localhost:8090/test1 it neither finishes download nor can be played.[libx264 @ 0x26078e0] VBV underflow (frame 2359, -93296 bits)
[libx264 @ 0x26078e0] VBV underflow (frame 2361, -132704 bits)
[libx264 @ 0x26078e0] VBV underflow (frame 2362, -11856 bits)
[libx264 @ 0x26078e0] VBV underflow (frame 2363, -6048 bits)
[libx264 @ 0x26078e0] VBV underflow (frame 2364, -4232 bits)
[libx264 @ 0x26078e0] VBV underflow (frame 2365, -14240 bits)
[libx264 @ 0x26078e0] VBV underflow (frame 2366, -53224 bits)
I tried to add an ASF stream and download it but it couldn't be played by any player.
Is there some mistake during file upload?
Results 1 to 1 of 1
ffserver cannot connect to rtsp
By newfoundstory in forum Video Streaming DownloadingReplies: 3Last Post: 29th Apr 2016, 09:59 -
Ffserver
By Ansii in forum Video Streaming DownloadingReplies: 3Last Post: 19th Apr 2016, 17:49 -
Issue with Yamb and MP4Box (adding audio-stream to video-stream)
By slax65 in forum Video ConversionReplies: 2Last Post: 21st May 2015, 06:39 -
Streaming (Video) Server / Video Upload on Website / Encoding
By steward in forum Video ConversionReplies: 4Last Post: 30th Oct 2014, 04:15 -
Help streaming /dev/video0 over http using VLC or ffserver/ffmpeg
By limiteddi in forum Video Streaming DownloadingReplies: 0Last Post: 26th Dec 2013, 22:22
