Downloaded and installed AVIdemux 2.7.1 and went to chop a commercial from an MKV with HEVC video. It has a bug. If you use the next keyframe button to set start and end markers, it complains that they're not on keyframes. Use the previous keyframe button and there are no complaints.
However, I get identical corruption for a few frames after the edit if I set the end marker with the next or previous button. The only difference with using previous is there's one additional frame left in. I'm doing a passthrough copy of audio and video.
Before editing those frames are fine.
So, is there another program that can edit this file, with passthrough for video and audio, that won't screw up a few frames?
Hi,
I'm using Avidemux. To skip to next I frame or previous I frame using arrows Up or Down. For next frame arrows right or left. You can also try combination with shift or ctrl for faster movment in timeline. I'm cutting start and end of HEVC recordings frequently in direct stream copy, and have no troubles. Only once. It gets me a warning. Probably because I use UI buttons. Still not sure why.
So probably only UI arrows are somehow affected.
Edit: Also have noticed, that is better press A and B point twice to get this point in precise position. So when set start point I always click on A twice (as double click) same for end B. But B needn't to be on I frame and frame accuracy there isn't so much important.
BernixLast edited by Bernix; 25th Jun 2018 at 01:11. Reason: Edit
I dunno why it's corrupting some frames after the cut. It jumps back and forth a bit like it's swapped the order of alternating frames with a bit of blockiness like there's missing data. The end frame of the commercial is solid black and the next frame is much lighter. It should be a very clean break, not depending on any prior data to display properly.
Hi,
it is not always I-frame even scene change is really big. Typ of frame you can see bellow the timeline. But I'm sure, you knows it. I recording from DVB-T2 to tsv format. Renaming to TS. When loaded this to Avidemux, there is not too much keyframes. So I remux it to mkv in mkvtoolnix, then load to avidemux and situation with keyframes is much better. Don't know why, but it is this weird behavior. Probably someone will explain it.
Also if you want cut on I frame (I frame included), you have to have it on this I frame set and then delete. Not frame before. But I think, you all this know. Just to clarify it.
BernixLast edited by Bernix; 25th Jun 2018 at 05:24. Reason: Edit
mkvmerge gui is corrupting my mkv files when muxing
By steve1232 in forum Newbie / General discussionsReplies: 51Last Post: 25th Feb 2022, 12:46 -
Addressing Frames/Slices/CTUs in HEVC
By Bezutrix in forum Newbie / General discussionsReplies: 1Last Post: 8th Feb 2017, 16:59 -
HEVC MKV to mp4?
By gott4 in forum Video ConversionReplies: 8Last Post: 9th Oct 2015, 08:49 -
Samsung TS (HEVC) into MKV
By Camboui in forum Newbie / General discussionsReplies: 7Last Post: 14th Aug 2014, 14:31 -
Program for adding chapters to mkv keyframes
By johns0 in forum Video ConversionReplies: 5Last Post: 12th Sep 2013, 06:23
