Hi,
I have an Acer Spin 513-51 58W laptop, which I am hoping to get working with aSamsung Syncmaster 206BW monitor which I bought new in 2007.
This is just a stop-gap measure to allow me some time to save for two state ofthe art monitors; I realize that the monitor will probably not even be able tohandle 1080p.
The Spin 5 has the following connections:
1 x USB 3 ports
2 x USB 2 ports
1 x HDMI port
The Syncmaster has the following connections:
1 x 15 pin D-Sub (RGB IN) port
1 x DVI (DVI IN HDCP) port
I have a few questions about this:
1. Is it possible to get the monitor working with the Spin 5?
2. If it is possible to get the Spin 5 and Syncmaster 206BW to work together,what connections should I use? HDMI on the Spin 5 to DV on the monitor?Or can I connect the the
monitor to one of the USB ports on the Spin 5?
Many thanks in advance for any help you can give me with this.
8 GB RAM
256 GB SSD
Intel i5-6200U CPU @ 2.30GHz, 2401 Mhz, 2 Core(s), 4Logical Processor(s)
Intel HD Graphics 520
Get an HDMI to to DVI adapter.
Complete cable:
https://www.amazon.com/AmazonBasics-HDMI-Output-Adapter-Cable/dp/B014I8UL8U/ref=sr_1_1...i+to+dvi&psc=1
If you have a spare HDMI cable:
https://www.amazon.com/AmazonBasics-HDMI-DVI-D-Adapter-2-Pack/dp/B06WVSLSP3/ref=sr_1_6...70_&dpSrc=srch -
Hi lingyi,Many thanks for your reply.
That was exactly the kind of information I was looking for.
acer ed242qr monitor getting distorted
By johns0 in forum ComputerReplies: 5Last Post: 15th Jun 2021, 04:10 -
Blu-Ray drive spin down problem
By RaptorZX3 in forum DVD & Blu-ray WritersReplies: 6Last Post: 7th Apr 2016, 13:12 -
Spin down (sleep) hdd in enclosure
By kyrcy in forum ComputerReplies: 9Last Post: 13th Aug 2015, 23:45 -
Control PotPlayer on Monitor 1 play video on Monitor 2
By CyberDude4819 in forum Software PlayingReplies: 4Last Post: 5th Dec 2014, 11:16 -
Would this Set Top Box and this PC Monitor combo work?
By Zeptinune in forum Newbie / General discussionsReplies: 16Last Post: 10th May 2014, 12:03
