Howdy,
I have some videos on an old MiniDV camcorder that I offloaded into AVI files. It broke the 40 minute video into 4 files. three of them are 12:30 and the last one is 3:32. If I open up any of the individual files, they all show the correct length.
I added the first file into VirtualDub just fine. I then did the Append AVI segment and selected the second one. That inflated my video from 12:30 to 41:04 instead of 25:00 like it should have. The total frames also jumped from 22500 to 73868 instead of 45000. Adding the third 12:30 file jumped the total up to 57:07.
I've never had this problem before. Can anyone recommend what might be causing this?
The end result I need is an MP4 file that is a combination of the 4 files I have. Normally I do it in two steps (Join and then Convert) but I'm open to other options if anyone has them.
Thanks!
				Results 1 to 9 of 9
	By default VirtualDub automatically appends all sequentially numbered files when you append. So if you have file1.avi, file2.avi, file3.avi, and file4.avi, and you open file1.avi, then append file2.avi, file3.avi and file4.avi will automatically be appended too. Notice at the bottom of the append dialog there's the option "Autodetect additional segments by filename".
	Oh, maybe that's what it was doing. A few of the files did have numbers at the end like 1, 2, 3. SO maybe it was appending all of them and I didn't notice. I ended up using AVIDemux instead since I had that as well and it seemed to work just fine. I'll keep that in mind for next time though.
 Thanks!
	Notice how the running time added up to that of all four clips after appending the second.
	Could also depend on how you cut up the files.
  Issues combining 2x mp4 h264 AAC video filesBy russt93 in forum EditingReplies: 8Last Post: 15th Apr 2018, 14:30
  Wrong video length after remuxingBy x264 in forum Newbie / General discussionsReplies: 5Last Post: 17th Feb 2018, 11:42
  Combining mkv files (video, audio, subtitles) to create a proper episode...By Cinderwolf in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2017, 22:16
  Weird - Video Files Copied from DVD with VOB2MPG different lengthBy GeoffWA in forum DVD RippingReplies: 10Last Post: 18th Aug 2016, 02:34
  Stream length is wrong in AudacityBy sambat in forum AudioReplies: 8Last Post: 4th Nov 2014, 13:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
