  1. hello all, i am looking for a video that is available on the link below with only 4 days left after which it will expire forever, can anyone please guide me how to get it, or please download and share it with me...
    http://www.channel4.com/programmes/food-unwrapped/on-demand/65676-034
    it is very urgent please as the link is expiring in 4 days
    regards from Invictus
  2. Member DB83's Avatar
    Jul 2007
    A little tip.
    If you want help then do not write "Help urgently needed please" .
    That sort of header is non-specific and will be ignored by most.
    Did you think that the thumbnail was representative of the actual content ? BTW It is not.
    A UK proxy should be able to grab it. I got bored within a few minutes.
    USA
    invictus, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics.
    I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
  4. ok Sir, noted for future reference please
    but anyone please help me on my actual request
  5. Member DB83's Avatar
    Jul 2007
    I took another look and my downloaders report a 'protected' stream.
    Now someone with more knowledge might be able to grab it otherwise screen-recording is the only option.
  6. I couldn't figure out how to download, but you can screen capture with free screen capture software, Debut Free.
    Link to screen capture software:
    https://files.videohelp.com/u/61125/debutsetupfree.zip
    Problem is, I use Hideallip ip software for UK and they now only let you use the free version for 20 minutes. So I captured 20 minutes. Also, I didn't size the recording window correctly, so the subtitles are cut off. Also, there is some buffering. All in all, not too good.
    Link to captured video:
    https://files.videohelp.com/u/61125/Un.avi
