I have a divx file in which the audio precedes the video, and when I load the file into VirtualDub, it recognizes the error. This is the exact message:
"VirtualDub has detected an improper VBR audio encoding in the source of the AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 59633 ms of skew from the video stream. If this is unacceptable, decompress the entire audio stream to an uncompressed WAV file with a constant bitrate encoder. (bitrate: 139.8 +- 32.2 kbps)"
This is my first time experience with using VirtualDub, so try to excuse my incompetency. The file is loaded into VirtualDub, and I am able play it while VD resyncs (redub) the entire file. My question is, how do I saved the corrected version? I tried to use the "save as .avi" function, but all it does is save the exact file without the audio/video corrections. There might be a real easy answer to this, so if anybody knows, thank you very much for your help.
Results 1 to 12 of 12
STELEATSEA, here is my first question: Is the audio out of sync with the video? Iam confused to what you are asking because virtualdub should not be used as save avi. Please answer my 1st question and we can start from there. VCD4ME
load your file into VDub and select save wav in the file pull down menu. this will create a very large wave file of the audio track from your video.
when that is done select direct stream copy in the video pull down menu.
now in the audio pull down menu select WAV audio and load the wav file you created. now set up the compression setting.
now in the file pull down menu select save as avi and give your new file a unique name.
if the audio is still out of sync then open the audio pull down menu in VDub and select interleaving and you will find a box to add an audio skew correction value in milliseconds.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
You will have to save as avi again! to new file if you are adjusting the inerleaving skew
Don't you just love it when someone like this newbie (first post) askes a question and 4 of us try to help him and he doesn't even respond
I wonde if he's even been back here to see if his question has been answered.We were all NEWBIES once and the only stupid question is the one that's not asked? -
can someone help me
i want to know how and what programs to use to split mpeg files
THANKSS
actually this time it was quite productive for meOriginally Posted by vcd4me
but yeah it's real annoying if you don't even get a thanks or something... -
"can u tell me how to split mpegs in tmpenc"
Look over to the left of the site. You use TMPGEnc's mpeg tools.
http://www.vcdhelp.com/tmpgencedit.htm
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub Conversion Question
By zenzen1 in forum Video ConversionReplies: 14Last Post: 11th Apr 2009, 10:15 -
Virtual Dub 1.8.5 Editing question
By zenzen1 in forum EditingReplies: 3Last Post: 27th Sep 2008, 05:55 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
