Hi.
I have a bunch of srt files that I need to have all in uppercase. I use Subtitle Edit to convert one file at a time but it would be so much faster to batch convert all of them.
I'm pretty bad at the command line thing, I'm not sure how it works, but is there a way to batch convert my files?
Thank you![]()
You could do this in Notepad++ with the "Replace All in All Open Documents" function using regular expressions. Search for (^.*$) and replace with \U\1.
Works
Dialogue: Marked=0,0:00:28.60,0:00:33.80,*Default,NTP,0000,0 000,0000,!Effect, ♪ When I was just a little girl ♪
Dialogue: Marked=0,0:00:33.88,0:00:39.04,*Default,NTP,0000,0 000,0000,!Effect, ♪ I asked my mother, what will I be? ♪
Dialogue: Marked=0,0:00:40.12,0:00:42.72,*Default,NTP,0000,0 000,0000,!Effect, ♪ Will I be pretty? ♪
Dialogue: Marked=0,0:00:42.80,0:00:45.24,*Default,NTP,0000,0 000,0000,!Effect, ♪ Will I be rich? ♪
Dialogue: Marked=0,0:00:45.32,0:00:49.64,*Default,NTP,0000,0 000,0000,!Effect, ♪ Here's what she said to me ♪
Dialogue: Marked=0,0:00:49.72,0:00:53.84,*Default,NTP,0000,0 000,0000,!Effect, ♪ Que sera, sera ♪
Dialogue: Marked=0,0:00:53.92,0:00:59.40,*Default,NTP,0000,0 000,0000,!Effect, ♪ Whatever will be, will be ♪
Dialogue: Marked=0,0:00:59.48,0:01:04.80,*Default,NTP,0000,0 000,0000,!Effect, ♪ The future's not ours to see ♪
Dialogue: Marked=0,0:01:04.89,0:01:07.77,*Default,NTP,0000,0 000,0000,!Effect, ♪ Que sera, sera ♪
Dialogue: Marked=0,0:01:08.65,0:01:13.49,*Default,NTP,0000,0 000,0000,!Effect, ♪ What will be, will be ♪
Dialogue: Marked=0,0:01:14.85,0:01:19.81,*Default,NTP,0000,0 000,0000,!Effect, ♪ When I was just a child in school ♪
Dialogue: Marked=0,0:01:19.89,0:01:25.97,*Default,NTP,0000,0 000,0000,!Effect, ♪ I asked my teacher, what should I try? ♪
Dialogue: Marked=0,0:01:26.05,0:01:28.85,*Default,NTP,0000,0 000,0000,!Effect, ♪ Should I paint pictures? ♪
Dialogue: Marked=0,0:01:28.93,0:01:31.53,*Default,NTP,0000,0 000,0000,!Effect, ♪ Should I sing songs? ♪
Dialogue: Marked=0,0:01:31.61,0:01:35.57,*Default,NTP,0000,0 000,0000,!Effect, ♪ This was her wise reply ♪
Dialogue: Marked=0,0:01:35.65,0:01:39.89,*Default,NTP,0000,0 000,0000,!Effect, ♪ Que sera, sera ♪
Dialogue: Marked=0,0:01:39.97,0:01:44.93,*Default,NTP,0000,0 000,0000,!Effect, ♪ Whatever will be, will be ♪
Dialogue: Marked=0,0:01:45.01,0:01:49.94,*Default,NTP,0000,0 000,0000,!Effect, ♪ The future's not ours to see ♪
Dialogue: Marked=0,0:01:50.02,0:01:54.18,*Default,NTP,0000,0 000,0000,!Effect, ♪ Que sera, sera ♪
Dialogue: Marked=0,0:01:55.18,0:02:01.10,*Default,NTP,0000,0 000,0000,!Effect, ♪ What will be, will be... ♪ ♪
Dialogue: Marked=0,0:02:05.38,0:02:07.38,*Default,NTP,0000,0 000,0000,!Effect,Damn.
Dialogue: Marked=0,0:02:07.46,0:02:09.42,*Default,NTP,0000,0 000,0000,!Effect,It's your turn, Heather.
Dialogue: Marked=0,0:02:12.14,0:02:15.06,*Default,NTP,0000,0 000,0000,!Effect,No, Heather. It's Heather's turn.
Dialogue: Marked=0,0:02:15.14,0:02:17.10,*Default,NTP,0000,0 000,0000,!Effect,Heather.
Dialogue: Marked=0,0:02:19.50,0:02:21.10,*Default,NTP,0000,0 000,0000,!Effect,Sorry, Heather.
Dialogue: Marked=0,0:02:21.18,0:02:25.86,*Default,NTP,0000,0 000,0000,!Effect, ♪ Que sera, sera ♪
Dialogue: Marked=0,0:02:25.94,0:02:31.30,*Default,NTP,0000,0 000,0000,!Effect, ♪ Whatever will be, will be ♪
Dialogue: Marked=0,0:02:31.38,0:02:36.03,*Default,NTP,0000,0 000,0000,!Effect, ♪ The future's not ours to see ♪
to
DIALOGUE: MARKED=0,0:00:28.60,0:00:33.80,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHEN I WAS JUST A LITTLE GIRL ♪
DIALOGUE: MARKED=0,0:00:33.88,0:00:39.04,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ I ASKED MY MOTHER, WHAT WILL I BE? ♪
DIALOGUE: MARKED=0,0:00:40.12,0:00:42.72,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WILL I BE PRETTY? ♪
DIALOGUE: MARKED=0,0:00:42.80,0:00:45.24,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WILL I BE RICH? ♪
DIALOGUE: MARKED=0,0:00:45.32,0:00:49.64,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ HERE'S WHAT SHE SAID TO ME ♪
DIALOGUE: MARKED=0,0:00:49.72,0:00:53.84,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪
DIALOGUE: MARKED=0,0:00:53.92,0:00:59.40,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHATEVER WILL BE, WILL BE ♪
DIALOGUE: MARKED=0,0:00:59.48,0:01:04.80,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ THE FUTURE'S NOT OURS TO SEE ♪
DIALOGUE: MARKED=0,0:01:04.89,0:01:07.77,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪
DIALOGUE: MARKED=0,0:01:08.65,0:01:13.49,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHAT WILL BE, WILL BE ♪
DIALOGUE: MARKED=0,0:01:14.85,0:01:19.81,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHEN I WAS JUST A CHILD IN SCHOOL ♪
DIALOGUE: MARKED=0,0:01:19.89,0:01:25.97,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ I ASKED MY TEACHER, WHAT SHOULD I TRY? ♪
DIALOGUE: MARKED=0,0:01:26.05,0:01:28.85,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ SHOULD I PAINT PICTURES? ♪
DIALOGUE: MARKED=0,0:01:28.93,0:01:31.53,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ SHOULD I SING SONGS? ♪
DIALOGUE: MARKED=0,0:01:31.61,0:01:35.57,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ THIS WAS HER WISE REPLY ♪
DIALOGUE: MARKED=0,0:01:35.65,0:01:39.89,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪
DIALOGUE: MARKED=0,0:01:39.97,0:01:44.93,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHATEVER WILL BE, WILL BE ♪
DIALOGUE: MARKED=0,0:01:45.01,0:01:49.94,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ THE FUTURE'S NOT OURS TO SEE ♪
DIALOGUE: MARKED=0,0:01:50.02,0:01:54.18,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪
DIALOGUE: MARKED=0,0:01:55.18,0:02:01.10,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHAT WILL BE, WILL BE... ♪ ♪
DIALOGUE: MARKED=0,0:02:05.38,0:02:07.38,*DEFAULT,NTP,0000,0 000,0000,!EFFECT,DAMN.
DIALOGUE: MARKED=0,0:02:07.46,0:02:09.42,*DEFAULT,NTP,0000,0 000,0000,!EFFECT,IT'S YOUR TURN, HEATHER.
DIALOGUE: MARKED=0,0:02:12.14,0:02:15.06,*DEFAULT,NTP,0000,0 000,0000,!EFFECT,NO, HEATHER. IT'S HEATHER'S TURN.
DIALOGUE: MARKED=0,0:02:15.14,0:02:17.10,*DEFAULT,NTP,0000,0 000,0000,!EFFECT,HEATHER.
DIALOGUE: MARKED=0,0:02:19.50,0:02:21.10,*DEFAULT,NTP,0000,0 000,0000,!EFFECT,SORRY, HEATHER.
DIALOGUE: MARKED=0,0:02:21.18,0:02:25.86,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪
DIALOGUE: MARKED=0,0:02:25.94,0:02:31.30,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHATEVER WILL BE, WILL BE ♪
DIALOGUE: MARKED=0,0:02:31.38,0:02:36.03,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ THE FUTURE'S NOT OURS TO SEE ♪
DIALOGUE: MARKED=0,0:02:36.11,0:02:40.95,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪
DIALOGUE: MARKED=0,0:02:41.03,0:02:46.03,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ WHAT WILL BE, WILL BE ♪
DIALOGUE: MARKED=0,0:02:46.11,0:02:53.47,*DEFAULT,NTP,0000,0 000,0000,!EFFECT, ♪ QUE SERA, SERA ♪ -
Yes it works, you probably forgot something like check regular expression or something like this.
How to batch convert/multiplex any files with ffmpeg
By Baldrick in forum User guidesReplies: 215Last Post: 1st Dec 2023, 11:38 -
Batch Run Hard code subtitles to video files
By kamalakar108 in forum MacReplies: 64Last Post: 19th Jan 2018, 09:34 -
Mux Batch convert MKV to MP4 with subtitles in Linux
By coquex in forum Video ConversionReplies: 7Last Post: 17th Jun 2016, 17:47 -
Batch script for forcing subtitles on MKV files.
By hemstock in forum SubtitleReplies: 2Last Post: 9th Oct 2015, 15:40 -
Batch muxing video files with subtitles
By calexicoca in forum SubtitleReplies: 4Last Post: 16th May 2015, 09:31
