Hello All,
I have a video file that will not play on my settop Blu-ray player.
The error it gives says that it is not H.264
Here is the media info dump...
How to I get it to play???
What software can I use to convert it???
General
Complete name : E:\ Videofilename.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 301 MiB
Duration : 7 min 55 s
Overall bit rate : 5 308 kb/s
Writing application : Lavf55.48.100
Video
Format : AVC
Format profile : High@L4.2
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 3 frames
Codec ID : avc1
Duration : 7 min 54 s
Bit rate : 5 202 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.042
Stream size : 295 MiB (98%)
Audio
Format : AAC
Format profile : LC
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 93.6 kb/s
Channel(s) : 2 channels
Channel(s)_Original : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 5.30 MiB (2%)
Default : Yes
Alternate group : 1
TIA
1080p at 60 fps is not supported by by the Blu-ray spec. Some players can play it, apparently not yours. You might try changing the Profile@Level flag to 4.1 to see if you can trick your player into playing it.
First, make a backup copy of your file then try h.264 Level Editor: https://coolsoft.altervista.org/en/h264leveleditor
Keep in mind that all h.264 Level Editor does is change the Profile@Level flag. It doesn't change the properties of the encoded video or audio. So the Blu-ray player still may not play the file. Or it may play the file but give jerky playback, stuttering audio, etc.
If the Blu-ray player can play mp4 videos (not all Blu-ray players can do so) it can probably handle the aac audio. That's the most common audio codec used in mp4.
region free blu ray player suddenly won't play certain set of disks
By fredgarv in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Apr 2018, 22:56 -
mkv won't play on Blu-ray after mkvmerge
By smogo in forum Video ConversionReplies: 28Last Post: 14th Jan 2017, 03:34 -
Blu-ray player to play "X-Men: Days of Future Past" blu-ray
By nekros111 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 6th Sep 2015, 04:06 -
Blu-ray player won't play backups
By Yanta in forum DVD & Blu-ray PlayersReplies: 12Last Post: 13th Jun 2015, 02:18 -
Samsung Blu-Ray Player BD-D5900 won't play subtitles
By hashim in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd May 2014, 14:55
