Hii, please can help a cat?
I have 2 audio files: 1.wav and 2 .wav.
Both are stereo (L+R) audio files.
I need to have an output.wav that is the "merge" of 1.wav and 2.wav so that output. wav is a 4 "channel" audio file. Is it possible with ffmpeg? thanks
There are multiple ways to skin a cat, if the cat is simply to lazy to do some reading and searching,...
https://trac.ffmpeg.org/wiki/AudioChannelManipulation should help to understand how what you want can be done in ffmpeg.
There is no example which directly solves you problem, but it should help enough for you to figure out how it works.users currently on my ignore list: deadrats, Stears555, marcorocchini -
LOL. Il Gato Pigro does not figure out how anything works. It only eats from a silver tray.
ffmpeg split audio channels
By Selur in forum Newbie / General discussionsReplies: 9Last Post: 27th Jan 2017, 18:14 -
(Help Needed with ffmpeg) how do i batch merge audio files to video files
By wander799 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2016, 15:40 -
ffmpeg: if inputfiles is mono or stereo ---> always save .wav in stereo
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2014, 10:42 -
What is the difference between Stereo, 2 Channels and Dual Stereo?
By LeoKac in forum AudioReplies: 4Last Post: 22nd Sep 2014, 18:05 -
How To Merge Wav Files together
By chobo2 in forum AudioReplies: 19Last Post: 24th Nov 2013, 10:48
