Hello. Yesterday i downloaded Blu-Ray movie. This Blu-Ray made from UHD 4K. Quality more better like license blu-ray. How make this downscale without loss quality?
Ouput file blu-ray from 4K:
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 h 5 min
Bit rate mode : Variable
Bit rate : 26.9 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.541
Stream size : 23.6 GiB (77%)
Results 1 to 10 of 10
What movie are you trying to downscale?
It doesn't matter. I have different movies. I want to know how this guy make release. How convert 4K to Blu-ray better that license disk.
A couple of quotes - google search
"Better compression" means better quality at the same size as those other codecs, smaller size with the same quality, or something in between. x264 is an open source h.264 encoder. h.264 was worked on jointly by ITU & MPEG (so aka MPEG 4-part10 as well as AVC and also JVT "joint video team").
x264 is a free software library developed by VideoLAN for encoding video streams into the H.264/MPEG-4 AVC format. It is released under the terms of the GNU General Public License.
https://www.videolan.org/developers/x264.htmlSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
To repeat:
x264 is an h.264 encoder. h.264 is the codec.
h.265 is not valid for BluRay. h.265 is UHD only.
https://www.videohelp.com/hd#techLast edited by LMotlow; 22nd Jun 2018 at 14:25.
- My sister Ann's brother -
Ok. Why this rip is not present information like a Writing library and Encoding settings x264?
Not every encoder puts that information in the video stream. It can also be removed if you don't want it.
x264 is generally considered one of the best h.264 encoders in terms of visual quality per bitrate.
Best way to convert an MKV file to Blu-ray?
By hbenthow in forum Authoring (Blu-ray)Replies: 28Last Post: 21st Jan 2022, 07:05 -
Convert MKV to Blu-ray
By chang123 in forum Authoring (Blu-ray)Replies: 11Last Post: 12th May 2016, 13:00 -
Convert PAL Blu-ray to NTSC?
By Todd Sauve in forum Authoring (Blu-ray)Replies: 38Last Post: 25th May 2015, 14:05 -
Simplest way to convert Blu-Ray .sup to .srt?
By Gurd99 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2015, 01:42
