Goal: Trying to avoid unnecessary transcoding due to eac3 audio streams on some mkv files in my library by adding a second (converted/transcoded) ac3 audio stream to mkv files. (While still preserving original mkv/eac3 streams)
Disclaimer: I’m new to this sort of thing and the only method I’ve found that works is to manually use these GUI apps with the following steps...
Current Working Method:
1. Using UsEac3To:
a. Demux mkv video & eac3 audio streams
b. Use libAften to encode a new ac3 stream from the demuxed eac3 stream
2. Using MKVToolNix GUI:
a. Use "multiplexing" task to remux mkv video stream and eac3/ac3 audio streams (ac3 set to default audio track)
Result: Mkv file with 2 audio streams (default set to ac3) able to direct stream without the need for transcoding.
Problem: This is far too many steps if I'm trying to convert an entire season. I have hundreds of files that could benefit from the addition of a default ac3 audio track.
Failed attempts using existing AIO tools...
1. Attempts using PopCorn MKV AudioConverter failed (Received "VideoTrack Not Found!" error, using latest version w/all necessary tools downloaded)
2. Attempts using MKV2AC3 failed (Fails to convert audio stream to ac3)
Questions:
1. Are there any other tools with which I can accomplish this?
2. How difficult would it be to create something like a batch file that I could drop video files onto in order to create the desired result? (Something that could do batch processing within a folder would be amazing)
Any direction here would be greatly appreciated. Apologies in advance if I used any incorrect terminology. Please let me know of any errors and I'll clarify/fix them.
How to demux AC-3 audio stream from *.mkv video?
By pxstein in forum Video ConversionReplies: 2Last Post: 19th Apr 2017, 04:54 -
How to properly demux, remux, and reauthor multi angle DVDs.
By Damned in forum Authoring (DVD)Replies: 10Last Post: 12th Sep 2016, 16:44 -
Remux if possible, if not, transcode all videos in a folder to MP4
By Airjrdn in forum Video ConversionReplies: 2Last Post: 6th Oct 2014, 15:13 -
Project Demux Normalize and Remux
By Teta in forum Video ConversionReplies: 1Last Post: 26th Sep 2014, 10:02 -
Trying to demux MKV file and remux as AVI with hardcode subs
By medicated in forum Video ConversionReplies: 24Last Post: 2nd Aug 2013, 21:48
