    Jun 2018
    Colombia
    Hi there,
    has anyone had problems importing text (.txt) into aegisub? I had no problems the first few times around, but now it seems it only imports and one subtitle text.
    In other words, I have a 2 page txt document, and when importing it, it shows as one long subtitle. Does anyone know what I am not doing right?
  2. I am PLEABS
    Apr 2018
    Earth
    i don`t have any problem on importing any txt to Aegisub
    how do you import them anyway? via copy and paste? if so do the paste on the "timeline" not the "textbox"
    Jun 2018
    Colombia
    I have imported the txt file. Made translation in Word, saved as txt. and imported as a whole through "open subtitles". this used to work for me, if i remember correctly. I will try your copy paste suggestion (comm C / V). Thanks
    Jun 2018
    Colombia
    It worked. how easy can it be. Thanks a lot.
