I would agree you dropping the time codes (timing information) seems to be the problem.
Extract the time codes using ffmpeg or other tools that are capable of doing so and add them afterwards using mp4fpsmod or similar.
Alternatively use ffmpeg for the whole remuxing while keeping the time codes.users currently on my ignore list: deadrats, Stears555, marcorocchini -
First one won't work because the remuxed file actually becomes a constant 25fps so all those extra frames are lost. As for the second one, not sure how to do that.
Something like (may need more options depending on your muxer):
Code:ffmpeg -i myinput -c copy -copyts myoutput
Variable Framerate to Constant Frame Rate
By jjcinema1 in forum Video ConversionReplies: 5Last Post: 6th Nov 2016, 20:29 -
Variable FrameRate
By Lazare Londaridze in forum Newbie / General discussionsReplies: 111Last Post: 11th Sep 2016, 02:00 -
Need help working with video with variable framerate
By nfshp253 in forum EditingReplies: 8Last Post: 31st Jan 2016, 02:59 -
Variable or Constant Framerate?
By JackDanielZ in forum Video ConversionReplies: 56Last Post: 4th Aug 2015, 07:14 -
MPEG-dash files from youtube: really variable framerate??
By flashandpan007 in forum Video Streaming DownloadingReplies: 4Last Post: 7th Jan 2014, 15:04
