Hello,
I am downscaling some 4K videos to 1080p with FFmpeg.
Both input and output should be standard H.264 - 8-bit, YUV 4:2:0.
I'm not quite sure if I understand the meaning of the following scaler flags - could you help me with these?Thanks!
- full_chroma_inp - this forces scaler to treat the input as full YUV 4:4:4, right? So it doesn't make sense to use it in my case?
- full_chroma_int - this is about using the full YUV 4:4:4 for internal processing when rescaling? Would it change anything if I apply -pix_fmt yuv420p afterwards anyway?
- accurate_rnd - "Enable accurate rounding". I assume it is somewhat slower but more precise mode? Which would result in a slightly sharper result?
Did that.
In my case - when both input and output are yuv420p - the following settings produce binary-identical output files:
Code:-sws_flags spline+accurate_rnd+full_chroma_int+full_chroma_inp -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -pix_fmt yuv420p -sws_flags spline+accurate_rnd -pix_fmt yuv420p
Well... knowing ffmpeg a bit i can say only one thing - perhaps they fixed some issues and some behaviour before non-default is now default but my observations on ffmpeg way before rev 3 leaded me to conclusion to use those flag as integral part of any resize on ffmpeg.
And one question - are you observing speed difference for those flags? If not then it may explain lack of difference between tries - perhaps they are active by default (so you could replace + sign with - sign and check how ffmpeg behave with explicitly disabled flags).
I will be not surprised if those flags are now active by default.
M2TS flags editor
By cybplanet in forum Video ConversionReplies: 6Last Post: 1st Dec 2017, 18:48 -
interlaced or progressive: where are the flags?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 30th Mar 2016, 11:23 -
Any under-100$ decent composite/component to HDMI scaler?
By stranno in forum Capturing and VCRReplies: 0Last Post: 3rd May 2015, 16:10 -
FFMpeg Flags
By alexander121 in forum AudioReplies: 2Last Post: 5th Apr 2015, 01:44 -
FREE New MyBD Blu-ray ripper, decrypter, scaler & converter to h265
By Mateo Dalmas in forum Latest Video NewsReplies: 24Last Post: 30th Oct 2014, 09:05
