Hello, I encode with x264 since many years, I know well its parameters. Recently, I get some videos difficult to encode, because there are many artifacts, crispy image, and when I try to encode these videos, these artifacts are still present and the result is ugly. Bellow a sample uncompressed with the artifacts at the top of the image.
Please, could you help me to set the x264 parameters in order to reduce these artifacts? I wish result in almost HD@1Mbps. Thanks in advance!
Original video : LINK
Compressed video : LINK
The sample @1Mbps is encoded with the following x264 parameters:
cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1000 / ratetol=1,0 / qcomp=0,60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1,40 / aq=1:1,00
I had something like that happen recently. A highly detailed, very contrasty black-and-white image. Rather than dink around with encoding params, I just gave it a very slight blur in my NLE. Barely discernable in the final application and it encoded perfectly.
I would try with the following changes.... though I'm afraid 1Mbps might be just too low a bitrate for such motion-heavy video at that res.
ref=4
deblock=1:1:1 (or maybe even 1:2:2)
me_range=16
keyint_min=1
Should give you at least a more pleasant looking result I hope... -
That will be difficult without nuking details. Depends what you understand by "almost HD".
You could apply a filter like
which will kill most of the artifacts of the source you mention, but unfortunately also some details.Code:fft3dfilter(3.5)
If you don't want to apply an avisynth noise filter you could also try the x264 internal noise filter --nr xxx which will improve compressability significantly.
At this low bitrate you may also use x265 (HEVC) instead of x264 as an encoder.Last edited by Sharc; 19th Jun 2018 at 02:38.
How to un-compress a video?
By jatt in forum Newbie / General discussionsReplies: 5Last Post: 8th Nov 2017, 17:02 -
How and what to use to compress video in Virtualdub
By carlmart in forum Video ConversionReplies: 10Last Post: 26th Apr 2017, 14:40 -
How to compress a video?
By Qayyum in forum Newbie / General discussionsReplies: 9Last Post: 17th Mar 2016, 08:52 -
Best way to compress video with least difference?
By Dan-D-Pak in forum Video ConversionReplies: 3Last Post: 11th Aug 2015, 13:09
