I have been editing videos and authoring DVDs using Pinnacle Studio for over 20 years and have never had this problem. Upgraded to Studio 20 finally (after many years of using Studio 12). Was able to create plenty of DVDs with Studio 20 that worked just fine. However, the last two videos I've created and written to DVD have caused an "incorrect disc" error, even though I've used the same methods for years. The DVDs work fine on the computer and in my old portable DVD player, but give an error in the blu-ray/DVD player and in the TV/DVD combo. Previous DVDs created the same way work fine, as do any DVDs I create using the new DVD menu file with an old rendered file that worked fine (i.e. using the DVD file and just replacing the AVI for chapter 1). Anytime I try to insert any newly created video file, I get an unreadable disc (whether AVI or WMV) Same thing when I write to DVD without a menu ... previously created video works fine, newly created doesn't. Writing RAW video to a DVD works fine, but as soon as I combine it with something else and render it ... the video causes the error. It's when I use the raw video and/or pictures to create a new AVI/WMV that I seem to have a problem. I've tried a new burner and reinstalling Studio, just to check, to no avail. Any ideas? (I can't go back and check the settings I used, because I never deliberately changed them ... I always used the defaults ...) (Sorry if this is rambling, I've tried so many different things I'm quite at a loss!)
Oh my goodness! You are my hero! That worked! I don't know how I accidentally changed it, but I changed it back and it works! Thank you!
Downloading HDS stream gives forbidden error or auth token error
By vishiwig in forum Capturing and VCRReplies: 1Last Post: 10th Jun 2017, 16:45 -
DVD Shrink error filed to read ifo parameter incorrect.
By abrogard in forum Authoring (DVD)Replies: 6Last Post: 25th Feb 2016, 05:19 -
VirtualDub error: Video Compressor error: The source image format is not
By maddie in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 11:12 -
Philips 5990/37... No Disc Error! Is it dead? Your insight please!
By frieday in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Jan 2015, 01:47 -
DVD Remake Pro- Unmerging a previously joined disc?
By Super Warrior in forum EditingReplies: 7Last Post: 23rd Oct 2014, 19:16
